Static align plane
Static align plane
Just loud thinking... When there is a change in upper tree, for example, that changes number of faces, than the following part of tree become corrupted mostly because sketches and datums get assigned to random faces. It seems like the id's of the faces can be changed (like renumeration). If so, would it be possible to set static id for faces at creation event and never change that id, so every object aligned to this id will stick always at proper position?
Re: Static align plane
Please search the forum for "topological naming". You will find lots of informations about this most severe issue.Dex wrote: ↑Thu Jan 04, 2018 10:32 am Just loud thinking... When there is a change in upper tree, for example, that changes number of faces, than the following part of tree become corrupted mostly because sketches and datums get assigned to random faces. It seems like the id's of the faces can be changed (like renumeration). If so, would it be possible to set static id for faces at creation event and never change that id, so every object aligned to this id will stick always at proper position?
Thank you:)
