Case with a linear pattern from a hole not working in PDN
alexis
Post by alexis »
Hi all,
On a piece where pockets were already applied along linear patterns without any problem :
I try to do a linear pattern from a hole.
- Make as usual a Datum plane on the pad face.
- Attach a sketch on this datum plane.
- Place a circle in this sketch.
- Make a hole.
- Try a linear pattern from this hole. It should be along sketche's vertical axis or simply X axis. No way.
"One transformed shape does not intersect support. Transformation failed".
1) Note that after hitting "Cancel" in the pattern dialog, the datum plane goes
super small, until recomputed.
2) With a fresh document and a single hole on a single pad, linear pattern works fine.
3) In the attached file, replace the hole by a pocket or a pad, try the linear pattern, it works.
AFAIK it looks like a (small) bug...
Cheers,
Alexis
OS: Debian GNU/Linux 9.3 (stretch)
Version: 0.17.13320 (Git)
Build type: Unknown
Hash: 12f3258ded6cd0471122c84ac5c43297812ac0c5
Python version: 2.7.13
OCC version: 6.8.0.oce-0.17
Locale: French/France (fr_FR)
plan-de-travail-test.fcstd
(77.89 KiB) Downloaded 66 times
Re: Case with a linear pattern from a hole not working in PDN
I can confirm the issue.
OS: Mac OS X
Version: 0.17.13346 (Git)
Branch: (HEAD detached at 22ee06d)
Hash: 22ee06de8441bfcc9fded2c6de4232d763fb11bc
Python version: 2.7.14
Qt version: 5.6.2
OCC version: 7.1.0
NormandC
Post by NormandC »
Off topic but I couldn't refrain myself ;)
alexis wrote: Mon Mar 05, 2018 9:39 pm - Make as usual a Datum plane on the pad face.
Why?!? What's to gain from creating a datum plane on a face, then attach a sketch to it? It amounts to attaching the sketch to the pad face. So why the redundant datum plane step?
Oh, and
alexis wrote: Mon Mar 05, 2018 9:39 pmOCC version: 6.8.0.oce-0.17
You would really gain from upgrading OCC to 7.1.0 at least, it solves a lot of issues, plus some Part tools require OCC 6.9.0 minimum.
It would not be difficult to repackage the opencascade packages we provide on the Ubuntu PPA for Debian.
