Crash on reducing chamfer size
Dear All,
I found a bug which crashes the program when reducing the chamfer size (e.g. to 0,6mm)
Please test the attached file changing last chamfer to 0,6 mm
Version: 0.17.13452 (Git)
Hash: 34633c144de9133c1f9aeb7da783f369cae9bfaf
Python version: 2.7.14
OCC version: 7.1.0
Locale: Italian/Italy (it_IT)
OCC version: 7.1.0
- BugSettingChamferto06mm.FCStd
- (148.2 KiB) Downloaded 72 times
Re: Crash on reducing chamfer size
No bug here.
I can change chamfer size to any value up to 1.8mm ( where it starts to go over hexagonal pockets ).
No bug here.
OS: Ubuntu Bionic Beaver (development branch)
Version: 0.17.13470 (Git)
Build type: Unknown
Hash: 656a669cb0dc3d2d3becf20a5330531233b56834
Python version: 2.7.14+
OCC version: 7.2.0
Locale: French/France (fr_FR)
No bug or chrash here.
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13472 (Git)
Build type: None
Hash: 7fd1e543febced04e779bda3debb7fbfdee7ffa3
Python version: 2.7.12
OCC version: 7.1.0
Confirmed on:
OS: Windows 7
Version: 0.17.13471 (Git)
Hash: 71f0f1a6d5a500c8221945417eb67a72b914919b
Python version: 2.7.8
OCC version: 7.1.0
It happens when typing the 0 if I enter .6 it works. If the input field is 0(.00) at any point during editing FreeCAD crashes.
OS: Windows 7
OCC version: 7.1.0
"fight the good fight"
I can reproduce a crash here, although it's not the 0.6 chamfer directly:
- use the panel to edit the chamfer
- it opens with the value of 1.000 selected
- if I start entering the value of 0.6 I start with a radius of "0" and before I can continue with ".6" FreeCAD crashes.
If the value isn't preselected try selecting it before changing.
OS: Mac OS X
Version: 0.17.13450 (Git)
Branch: (HEAD detached at 129e2f7)
Hash: 129e2f7a1b55c91880f2db2da264746acdc14d38
Qt version: 5.6.2
OCC version: 7.1.0
OS: Mac OS X
Qt version: 5.6.2
OCC version: 7.1.0
I too can reproduce the crash/no-crash scenario.
This seems similar to the problems with entering negative numbers in some fields. The parser immediately starts to work, and the negative sign is taken as an undo for the previous operation.
Many operations in FreeCAD allow for the complete entry into a number box before doing anything, but some operations seem to want to try to act on every single digit as entered. Seems like a bad idea in general. At best it causes a lot of cluttered action in the display, and at worst it causes an error or a crash.
OS: Windows 7
OCC version: 7.1.0
Gene
OS: Windows 7
OCC version: 7.1.0
Gene
Hello
I fixed your file.
What have I done?
I set the value Refine in the Data Tab of Mirror004 to true, the fillet took a different position.
I deleted Chamfer and Fillet and recreated it.
Now it seems to be working.
I work with
OS: Windows 7
OCC version: 7.1.0
and had received the following error message.
Problemsignatur:
Problemereignisname: BEX64
Anwendungsname: FreeCAD_017_13452.exe
Anwendungsversion: 0.0.0.0
Anwendungszeitstempel: 5ab6519e
Fehlermodulname: TKGeomAlgo.dll
Fehlermodulversion: 7.1.0.0
Fehlermodulzeitstempel: 5893c6c2
Ausnahmeoffset: 000000000012bb9c
Ausnahmecode: c0000409
Ausnahmedaten: 0000000000000000
Betriebsystemversion: 6.1.7601.2.1.0.256.1
Gebietsschema-ID: 1031
Zusatzinformation 1: 1e78
Zusatzinformation 2: 1e78cd82fb0a64f9ae39a27b1701bb81
Zusatzinformation 3: efab
Zusatzinformation 4: efabb60e6d3b2e8b1afa5ce8d8441644
Maybe it helps to prevent this behavior in case of a corrupted file.
Changes in the Data Tab have been accepted.
Bruno
I fixed your file.
What have I done?
I work with
OS: Windows 7
OCC version: 7.1.0
Problemsignatur:
Bruno
- BugSettingChamferto06mm_fix.FCStd
- (146.66 KiB) Downloaded 63 times
Confirmed, the error is fixed. Thank you for the speed.
