[FIXED] Using undo in Sketcher causes errors after the Big Merge
aapo
Re: [Bug?] Using undo in Sketcher causes errors after the Big Merge
Postby aapo » Fri Aug 23, 2019 9:27 am
Syres wrote:
Fri Aug 23, 2019 6:49 am
you'll notice that the constraints are removed from the first geometry as well as the actual undo the user wants to be achieved.
The constraints are not actually removed from the first geometry, they just disappear from the list and UI view, and they also seem to temporarily cease to cause any restrictions on the model. However, the constraints are still there, as exiting Sketcher and either a) using Sketch validator to fix the constraints, or b) simply doing a save-close-load cycle, restores the constraints.
realthunder
Postby realthunder » Fri Aug 23, 2019 11:16 am
I have just added fix for this. Please try build my LinkMerge branch here.
user1234
Postby user1234 » Fri Aug 23, 2019 1:41 pm
Hello!
I can not confirm if the error was before, because i do not much in the sketcher.
But i can conform that the LinkMerge branch have no errors in this
OS: Debian GNU/Linux 10 (buster) (X-Cinnamon/lightdm-xsession)
Version: 0.19.17899 (Git)
Build type: DebWithRelInfo
Branch: LinkMerge
Hash: a17196cdbe868c57e5cdee92b986f730d9956878
Python version: 3.7.3
Qt version: 5.11.3
setup.
Greetings
user
Syres
Postby Syres » Fri Aug 23, 2019 1:53 pm
Hello!
Thanks for the quick fix @realthunder and cheers to @user1234 for the positive swift feedback, I'll have to wait for the PR to be merged into master but in the meantime I can work fine with the 0.19.17651 build.
aapo
Postby aapo » Fri Aug 23, 2019 2:54 pm
Hopefully I did it correctly, as my git-skills are not top-notch, but I went with
$ git pull https://github.com/realthunder/FreeCAD/ LinkMerge:LinkMerge
And thus tried to make a local merge between a (local) newly created LinkMerge branch and your LinkMerge branch. Anyway, git pulled some changes that seemed to merge & start to compile ok, so something(TM) happened anyway. I'll have to just wait for the build to finish now. :)
aapo
Postby aapo » Fri Aug 23, 2019 3:32 pm
The compilation has finished, and I did some (very) basic Sketcher tests with the resulting FreeCAD binary. No problems with the Sketcher undo anymore, so I can confirm that your fix also works very well for my case. Nicely done, thanks! Curiously, the resulting FreeCAD still says it's "master" branch, but it does contain the LinkMerge branch fixes, at least according to git:
remote: Enumerating objects: 177, done.
remote: Counting objects: 100% (177/177), done.
remote: Compressing objects: 100% (41/41), done.
remote: Total 177 (delta 142), reused 166 (delta 136), pack-reused 0
Receiving objects: 100% (177/177), 107.91 KiB | 673.00 KiB/s, done.
Resolving deltas: 100% (142/142), completed with 46 local objects.
From https://github.com/realthunder/FreeCAD
 * [new branch]          LinkMerge  -> LinkMerge
 * [new tag]             0.17_pre   -> 0.17_pre
Anyway, I hope the fix lands into the real master soon! :D
OS: Debian GNU/Linux bullseye/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.17903 (Git)
Hash: 7dbca147bcd7358e3c00fe3437a8108235ed3fa9
Python version: 2.7.16+
aapo
Postby aapo » Fri Aug 23, 2019 5:20 pm
I reverted back to the official FreeCAD/master, and compiled again, and confirmed that the bug is still in there, and FreeCAD crashes. However, I manually cherry-picked your fix a17196c... from your tree, and patched the official FreeCAD/master branch with just this one commit, and compiled once again. Resulting binary worked, so the a17196c... fixes the bug also on top of the official master:
$ wget https://github.com/realthunder/FreeCAD/commit/a17196cdbe868c57e5cdee92b986f730d9956878.patch
$ git apply --stat a17196cdbe868c57e5cdee92b986f730d9956878.patch
 src/Mod/Sketcher/App/SketchObject.cpp       |   11 ++++-------
 src/Mod/Sketcher/Gui/ViewProviderSketch.cpp |   10 ++++++++++
 2 files changed, 14 insertions(+), 7 deletions(-)
$ git apply a17196cdbe868c57e5cdee92b986f730d9956878.patch
a17196cdbe868c57e5cdee92b986f730d9956878.patch:62: trailing whitespace.
            if(Constr->First < -extGeoCount || Constr->First >= intGeoCount
a17196cdbe868c57e5cdee92b986f730d9956878.patch:63: trailing whitespace.
                    || (Constr->Second!=Constraint::GeoUndef
a17196cdbe868c57e5cdee92b986f730d9956878.patch:65: trailing whitespace.
                    || (Constr->Third!=Constraint::GeoUndef
warning: 3 lines add whitespace errors.
$ make -j4
Git complained about some trailing whitespace in your commit, but it didn't of course have an effect on compiling. So, your fix works for me on top of the official master, and fixes the bug. Well done! :D
Version: 0.19.17875 (Git)
Hash: 6dae8f371735dd54630e6bfb07824c7796509824
aapo
Re: [FIXED] Using undo in Sketcher causes errors after the Big Merge
Postby aapo » Tue Sep 03, 2019 6:53 am
I just tested the latest official Windows Git build v0.19.18024, and undo worked great there. Which is no surprise, as the relevant bugfix by realthunder has finally been merged to the official master. So, this problem should be permanently fixed in all FreeCAD versions above ~ v0.19.18000. Thanks!
OS: Windows 10 (10.0)
Version: 0.19.18024 (Git)
Hash: 9cc8f6eb666b0a0ae2dc256f7bc0beb8c987710c
Python version: 3.6.8
Qt version: 5.12.1
