[fixed] [regression] Link feature broke PD's patterns dialog
uwestoehr
Re: [fixed] [regression] Link feature broke PD's patterns dialog
Postby uwestoehr » Sun Feb 16, 2020 3:52 pm
realthunder wrote:
Sun Feb 16, 2020 4:58 am
I have moved common logic in onSelectionChanged of various transformed task panels into the parent TaskTransformedParameters:originalSelected()
Cool feature! I hope that your toponaming stuff is merged soon after the release of 0.19 since toponaming is THE killer argument against using FC. And this it is sad because if this would be improved, FC is a super useful CAD program. Btw., I think also the Sketcher WB needs to be made toponaming-safe, right?
Besides this I need help with a special issue and since you know the internals of FC maybe you can help me:
- Take the current master and open there the fillet dialog.
- select an edge in the list and press DEL
result: nothing happens
- now press the Add button and then DEL
result: now the deletion is performed.
I found out that the reason is that after
Gui::Selection().addSelection(..)
is executed in TaskDressUpParameters::setSelection all keypresses are filtered. First after executing
Gui::Selection().clearSelection()
keypresses are taken into account. But of course one needs the active selection to show the user.
This issue also affects other WBs like FEM: https://forum.freecadweb.org/viewtopic.php?f=18&t=43402
Site Admin
Postby wmayer » Sun Feb 16, 2020 8:11 pm
In the output window you may get a warning: QAction::eventFilter: Ambiguous shortcut overload: Del
The reason is that if something is selected the global Delete command will be active, too. So there are two active QActions with the same shortcut and that's why nothing happens.
There is a trick to tell Qt to forward the key event to the task panel: override the event() method and handle the event type QEvent::Shortcut and accept the event if Del was pressed. Qt then emits a key event and directly sends it to the task panel.
uwestoehr
Postby uwestoehr » Sun Feb 16, 2020 8:57 pm
Many thanks! However since I am a real newbie in this regard, could you maybe give me some code lines and I'll put it in to the different dialogs (also for FEM)?
realthunder
Postby realthunder » Sun Feb 16, 2020 9:43 pm
Yes sure. In fact, my work on topo naming starts with Sketch, while I worked on Sketch Export, because I need a way to stabilize the exported Sketch elements.
wmayer wrote:
Sun Feb 16, 2020 8:59 pm
ping
Since its mentioned, just take the opportunity to ask. Do you think there's still time to merge the topo naming feature in 0.19?
uwestoehr
Postby uwestoehr » Sun Feb 16, 2020 9:49 pm
Well, some months ago I was very enthusiastic but now after working with the code AND FC itself almost daily, I think it is for now better to make 0.19 ready. For my taste there are too many issues and even crashes.
My proposal:
to start the (then 1.0 :D development cycle) directly after FC 0.19 is released.
For now let's focus on fixing bugs and testing the new features thoroughly.
Site Admin
Postby wmayer » Sun Feb 16, 2020 10:37 pm
No, we shouldn't because then too many things are under heavy change. IMO most of the current pending PR should be merged and then we should start the feature freeze.
realthunder
Postby realthunder » Sun Feb 16, 2020 11:23 pm
Yes, got it.
Site Admin
Postby wmayer » Mon Feb 17, 2020 12:01 am
Unfortunately, the key event is not handled automatically. It must be also explicitly handled by the task panel class: See git commit 7aad85e9c
Remark: The QAction should be a private member variable because accessing it with
QAction *action = ui->listWidgetReferences->actions().at(0); // we have only one action
is prone to fail when later a second action might be added.
uwestoehr
Postby uwestoehr » Mon Feb 17, 2020 9:00 am
Many thanks, also for the remark. I'll spread this change to the other dialogs as soon as my pending PR for the fillet dialog is merged.
