[Fixed] Base shape Binder cannot be used
from gif you may see error. I also attach the 3D model.
I modelled as follow:
create a Part
create several bodies
the item3 body was modelled as:
1 - create a binder to item 1 surfaces
2 - drawn a sketch of the body
3 - extruded the sketch
4 - added chamfer/radius >>> fails.
it it a bug?
Regards
Michele
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.
Release date: 2020/02/19 14:50:34
Python version: 3.6.9
Qt version: 5.9.5
create a Part
it it a bug?
Regards
Michele
Version: 0.19.
Qt version: 5.9.5
- SL30 00.01.00.FCStd
- (49.36 KiB) Downloaded 65 times
Re: [BUG?] Base shape Binder cannot be used
You are basing your sketch directly on the PartDesign ShapeBinder. I would use the ShapeBinder, but then create a PartDesign Plane that uses that ShapeBinder as reference. Then I would use the plane as support for the sketch. This seems to work to create the chamfer.
Uwe, not saying that you broke this, but since you modified the PartDesign task panels recently maybe you have a clue what is happening here. It's like the ShapeBinder can't be the first element inside the Body.
This is a regression. it worked in
OS: macOS High Sierra (10.13)
Version: 0.19.19541 (Git)
Hash: a797a4172709b82c6cd08dcf6df86cb789aaa3ce
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Qt version: 5.12.5
OCC version: 7.4.0
I had a brief look. The issue is triggered by this code in Feature.cpp:vocx wrote: ↑Sat Feb 22, 2020 4:25 am since you modified the PartDesign task panels recently maybe you have a clue what is happening here. It's like the ShapeBinder can't be the first element inside the Body.
if (BaseObject->isDerivedFrom(PartDesign::ShapeBinder::getClassTypeId())||
BaseObject->isDerivedFrom(PartDesign::SubShapeBinder::getClassTypeId()))
throw Base::ValueError("Base shape of shape binder cannot be used");
So we have a regression.
I reverted all my changes and went back to revision git commit 53bbf09b, then it works.
So will have to run some Git blame runs to see what commit triggers the regression.
[regression] Base shape Binder cannot be used
This commit causes the problem: git commit 3a9002217c8c8bc1:uwestoehr wrote: ↑Sat Feb 22, 2020 2:42 pm I reverted all my changes and went back to revision git commit 53bbf09b, then it works.
git.exe bisect bad
3a9002217c8c8bc13fa3e3e4630b7a5dfe0b9342 is the first bad commit
commit 3a9002217c8c8bc13fa3e3e4630b7a5dfe0b9342
Author: Zheng, Lei <realthunder.dev@gmail.com>
Date: Thu Feb 13 16:43:59 2020 +0800
PartDesign: fix FeatureDressUp base checking
src/Mod/PartDesign/App/FeatureDressUp.cpp | 24 ++++++++++++------------
src/Mod/PartDesign/App/FeatureDressUp.h | 2 --
2 files changed, 12 insertions(+), 14 deletions(-)
realthunder wrote: .
Re: [regression] Base shape Binder cannot be used
PR submitted here. Nice catch.
Re: [Fixed] Base shape Binder cannot be used
This might be a really dumb question, but this is the only thread where this error have been reported.
After using @realthunder brilliant PartDesign "Split Operation" operation I'm getting a split feature. If I select one of the fresh splits and make a body, I end up with BaseFeature ShapeBinder. And while I am able to use it as a reference, I am not able to modify it (I.e. Apply a chamfer or a filet). What I get is a message saying "Base Shape of Shape Binder cannot be used".
I understand that the ShapeBinder should only be used as a reference, but shouldn't splitting a body in two produce 2 modifiable bodies? Maybe I'm not using the approriate procedure to generate 2 separate bodies?
Edit: Some more info on this
Here's what I'm doing step by step:
https://www.youtube.com/watch?v=cvDKp7pBxgE
Here's a video by Oficine Robotica, which a 1:01 shows chamfers applied directly onto the shape binder (in the Tree)
https://youtu.be/wyCLoQLDJsc
Edit 2: Here's what makes it even weirder. I can apply a fillet (which would be illegal) if I add a random feature to the ShapeBinder. It's a way around it right now.
https://youtu.be/sriJyx3sG1s
Thank you in advance! Sorry if I'm being thick here.
OS: Windows 10 (10.0)
Version: 2020.1230.23076 +3055 (Git)
Branch: LinkStage3
Hash: c7f24fa0eb98232200ab5cae1ac3be8786a22c2c
Python version: 3.6.8
Qt version: 5.12.6
OCC version: 7.4.0.beta
If you find any PartDesign problem in my branch, you can either report as github issue (preferred). Or report to this thread.
This is a bug. I have just fixed it. Thanks for reporting.After using @realthunder brilliant PartDesign "Split Operation" operation I'm getting a split feature. If I select one of the fresh splits and make a body, I end up with BaseFeature ShapeBinder. And while I am able to use it as a reference, I am not able to modify it (I.e. Apply a chamfer or a filet). What I get is a message saying "Base Shape of Shape Binder cannot be used".
BTW, you can use Boolean feature to fork a new solid in the same body. Select the splitted solid, create the Boolean, and then check 'New solid' in the task panel. You can then do fillet or whatever on this boolean feature. You can use Boolean again in later time point to merge back the solid, and this time without checking 'New solid'.
Will do! I wasn't sure whether it was my incompetence or an actual problem.realthunder wrote: ↑Wed Jan 06, 2021 9:27 am If you find any PartDesign problem in my branch, you can either report as github issue (preferred). Or report to this thread.
Thanks again for your work, and the advice, I will look into Boolean a bit more.
