There is the 'PartialLoad' property of the binder to control the auto/manual loading of external document. I added some brief description of various properties in SubShapeBinder in that PR. Use mouse hovering in property view to see it.emills2 wrote: ↑Thu Mar 05, 2020 12:09 amis this documented?realthunder wrote: ↑Wed Mar 04, 2020 11:32 pm Yes it does, and better than Link in some use case, because unlike Link, the binder knows what is a Shape, and it will make a copy of the linked shape
App::link of sketch in PD Body
Re: App::link of sketch in PD Body
OS: Windows 10 (10.0)
Version: 0.19.19697 (Git)
Hash: 8832356802011bf5d70e9d6f0efa89c47bc70a91
Python version: 3.7.3
Qt version: 5.12.5
this is a pretty recent FreeCAD.
shown below are all the different model structures i tried: in every single case, drag sketch drop to binder, and also ctrl-drop to binder results in a hard crash, no error messages.
it hangs with the + or arrow icon on the mouse, then shuts down the FreeCAD window. a few times, my mouse turned into a system waiting icon but mostly frozen custom icon on mouse, and crash within seconds.
Qt version: 5.12.5
now with the regular binder:
editing the support link reveals that only the current file is in scope
direct drag and drop is explictly prohibited
these are the only methods i have found so far to interact with the contents of the binder.
if the body is active in the source file and i select the sketch and hit the create subshapebinder button, crash.
if the body is inactive in the source file and body is active in the receiving file, crash.
in this last attempt:
set body active in receiving file, select entire body in source file, hit create subshape binder:
-activates body in source file
-creates binder within source file body
-cyclic dependecy error
-removes binder from source file body
-no crash
if the current subshape binder handles cross file bindings, it is well hidden. maybe some other combination of active parts /active bodies? i tried a lot of variations there as well.
-no crash
Well, not recent enough. There is a fix of the crash six days ago.
Here is an easy way to create cross file binding. Create the body in the target file, without selecting anything (i.e. clear the selection), click the green binder button. This will create an empty binder. Then just drag the feature from the other file and drop to this binder. And once my last PR is accepted, you can use link property editor to select external object too. See the following screencast. Notice that the first think I did after created the body is to unselect it. When you click the binder button, it will create a binder that binds to the selection if there is any.
The screencast also shows the effect of 'PartialLoading'.
Thanks realthunder. i'm gonna get 0.19.1975 for now. i don't really know how to relate the version number to the commit number, but eventually the fixes will reach dev builds!
latest dev build, 6 days ago. i'm not sure if this capture the fix you mentioned
Version: 0.19.19758 (Git)
Hash: c165edd52c7f06ac09f992e5b5bf1d37661a8c0f
Qt version: 5.12.5
works for a binder to an extrusion inside a body. partial loading does not load change made in source file, and that's ok, i don't mind the source file being open.
trying to drop just a sketch into the binder still crashes though
making a Part > make face from wires (applied to the sketch) works!
so i have now correctly bound between files, but it's not a sketch, so the part designs tools won't operate on it in the receiving document. still progress! i can use the geometry as external geometry in a new sketch, so i could trace it, if i absolutely needed to get something done today.
it's kind of curious, since i can bind the sketch between bodies in the same document, and it does extrude directly, but that ability goes away when binding between files
it's not easy to always remember the selection sequence so that the receiving doc doesn't collapse in tree view when i got to select the source file sketch. if it does collapse, i can't drop to the binder.
Qt version: 5.12.5
I think still not. The PR is submitted earlier, but got merged I think just a day after.
There is another PR submitted 3 days ago to allow extrusion directly by selecting the whole binder, even the binder has multiple faces inside.it's kind of curious, since i can bind the sketch between bodies in the same document, and it does extrude directly, but that ability goes away when binding between files
During the development of App::Link the shape(less) nature came up often. During the development of PartDesign NEXT the (non)inclusive nature of the workflow came up often. This is what i guess @emills2 is asking about in this thread.
P.S. Eventually both areas will get tackled to the extent most people will accept the solutions as suitable and at that point FreeCAD will reach zen again.
Sorry i'm late about this, and want not hijack this thead again... but I add my 2 centsrealthunder wrote: ↑Fri Feb 28, 2020 10:18 am As for the PartDesign modeling using multiple bodies, I have plan to add property support for that. Multiple sub-bodies (or Solids) can be created inside the current PartDesign Body as an optional branch on the current linear history. Unlike body, each solid will not have its own placement, which is crucial so that the features that construct those solids can be freely referenced by other features without requiring a binder or link. In other words, features of solids within the same body all live in the same coordinate system.
I could agree with Zolko, maybe add another level with a new container could be quite painful. However, AFAIK and as realthunder said those sub-bodies could alows direct Xrefs by avoiding the use of shape binder between bodies.
If i had to choose, I would prefer sub-bodies rather to use shapebinders everywhere between actual bodies.
@Realthunder: you mind about sub-bodies created by user right? Manually? Or do you mind maybe sub-bodies generated automaticaly, where each sub-body would be a single solid?
