Feature Request: sketcher - Direct switch between reference and real geometry
RatonLaveur
Post by RatonLaveur »
Hello to all,
In order to construct a new sketch based on existing geometry:
The current workflow is:
- Reference geometry from the shape-binder of a sketch
- Reconstruct/retrace the geometry (3 positioned clicks for a single arc, can result in a large number of clicks).
Proposed improved workflow:
- Transform the reference into construction/real geometry (1 click on the "switch" button).
Is this feasible? is it even a reasonable expectation?
Re: Feature Request: sketcher - Direct switch between reference and real geometry
This has already been discussed several times. I think Abdullah has it on his radar. Meanwhile you may use CarbonCopy instead and delete unwanted geometry.
RatonLaveur
Thanks for the heads up. Will focus on getting better at Carbon Copy (currently i often fail at using it correctly).
dulouie
Post by dulouie »
There is a not merged PR for this. See https://github.com/FreeCAD/FreeCAD/pull/1421
Why was the PR closed?
But you can try realthunders fork, he has implemented this function to sketcher.
Enhanced sketch external geometry, which can be:
  • Defining, i.e. used for shape building
  • Frozen, i.e. no auto update when source geometry changes, but can be manually synchronized
  • Detached from source geometry
  • Re-attached
phpBB [video]
https://github.com/realthunder/FreeCAD_ ... 3/releases
RatonLaveur
Yay that is awesome! can't wait for RT's branch to be merged.
That person is quite baffling..
