Computer crash after changing pocket size
cappu
Postby cappu » Sat Jun 27, 2020 12:59 pm
My computer crashes after changing pocket size:
1) open RegalBuero (copy).FCStd https://www.magentacloud.de/lnk/ahAhDTWN
2) change WS to part-design
3) open last sketch043: RegalBuero/P2_KeinteilBoxen../B8_BodenHinten001/Seitenloecher/Sketch043
4) In this sketch043 change the very right-side hight-parameter from 32,8 to 33mm
5) close the sketch
6) look on cpu and RAM. On my PC CPU become 100% load (after aprox 5sec) and RAM starts slowly overflow (approx 30sec left until complete overflow)
I created bug-report : https://tracker.freecadweb.org/view.php?id=4378
issue #0004378
But I need to create a thread in form first. So, here it is. (hope it is the correct forum)
Does anyone's computer crashes at changing the pocket size too?
Thanks for info
mikeprice99
Re: Computer crash after changing pocket size
Postby mikeprice99 » Sun Jun 28, 2020 6:05 am
I note from your bug tracker entry that you're running on Ubuntu.
I've (tested as per your instructions) on Windows 10 (rev 21775) and could not replicate the problem.
Postby chrisb » Sun Jun 28, 2020 6:17 am
No problem here:
OS: macOS High Sierra (10.13)
Version: 0.19.21671 (Git)
Hash: f05253f882b336f56aae32593faa5676fd5aafdd
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Sorry if you see me again very annoyed. We don't aks for a topic here before creating a bug report, we ask for a discussion! And we do so for good reasons: to minimize the work for the developers. Here in the forum we have quite some knowledge to identify bugs, make proposals and so on.
Your version is not quite up-to-date, can you retry with the latest?
Of course FreeCAD should not crash, but meanwhile you should get your model right: Changing the constraint as described above shows many "Constraint xx is malformed" messages. Since you don't know from which sketch they come, you have to identify it. This can be rather tedious, e.g. by deleting some sketches at the end of the tre and see if the message still occurs.
Furthermore you may consider to pocket the oval only once and then apply a linear pattern.
Postby chrisb » Sun Jun 28, 2020 6:21 am
Memory usage goes up to more than 3.5G here. So you may simply have run out of memory?
freecad-heini-1
Postby freecad-heini-1 » Sun Jun 28, 2020 9:32 am
No problem here, on my old Packard-Bell Notebook Easynote LE69KB with Xubuntu 18.04 and Freecad 0.19:
OS: Ubuntu 18.04.4 LTS (XFCE/xubuntu)
Version: 0.19.
Branch: unknown
Hash: 79e11ce8a1c382d92af39d58dbd7e7ccc8c0fefa
Python version: 3.6.9
Qt version: 5.9.5
Site Admin
Postby wmayer » Sun Jun 28, 2020 10:41 am
I often have seen this kind of problem with OCC. The kernel from time to time tries to allocate a huge amount of memory -- sometimes it's legit I think but sometimes there is an integer overflow where an array of a size of several billion elements is created.
For the old 32-bit applications this was less of a problem because a process couldn't allocate more than 2 GB (with some special linking option it could be increased to 3 GB on Windows XP) and if the requested memory is too much a new handler is triggered. In FreeCAD we have implemented it to raise a memory exception.
Maybe it's an option to overwrite the global new operator https://en.cppreference.com/w/cpp/memor ... erator_new and raise an exception if a block seems ridiculously high.
Other options might be to set some hard limits for a process. Here are some references I found for Windows and Linux
Postby chrisb » Sun Jun 28, 2020 3:55 pm
There is an issue occurring in the model linked to the first post, which is not directly linked to OP's problem: On recompute of the last Sketch043 a message occurs "Sketcher constraint number 23 is malformed!". As mentioned above this occurs if changes are made in previous steps.
Is it worth a feature request to augment this message with the name or label of the sketch? It can be very difficult in bigger models to find the sketch containing the error.
Abdullah wrote:ping
abdullah
Postby abdullah » Thu Jul 02, 2020 3:39 pm
Abdullah wrote:ping
Sorry to come to this one so late.
That error message comes directly from the solver interface. It was not intended as an exception, so that the solve could continue (though I have serious doubt this is a sound decision, as malformed constraints are like a drunk driver going top speed in the motorway in the incorrect sense).
As the solver does not know about sketches, I have coded an additional error message to complement those errors (see last line):
Sketcher constraint number 24 is malformed!
Sketcher constraint number 28 is malformed!
Sketcher constraint number 46 is malformed!
Sketcher constraint number 56 is malformed!
Sketcher constraint number 80 is malformed!
EigenSparseQR, Threads: 1, Vectorization: On, Pivot Threshold: 1e-13, Params: 280, Constr: 280, Rank: 280
Sketcher::setUpSketch()-T:0.193
DL: tolg: 1e-80, tolx: 1e-80, tolf: 1e-10, convergence: 1e-10, dogLegGaussStep: FullPivLU, xsize: 189, csize: 189, maxIter: 100
DL: stopcode: 1, Success
Sketcher::Solve()-DogLeg-T:0.009
Sketch Sketch043 has malformed constraints!
I will be committing this soon.
All those constraints are tangency constraints. What is much more relevant for me is: How can one create tangencies to itself?
There are even several tangencies [(0,0), (0,0)].
I would really like to fix the bug that makes that possible, so if you manage to reproduce that, let me know.
Postby chrisb » Thu Jul 02, 2020 5:15 pm
I have no idea how this could have happened. But I have seen the message recently (perhaps I even reported it repeatedly) after making changes to previous steps and thus changing external geometry references.
It quite sure does not occur while working on the sketch itslef, that's why it stays rather long unattended, and when it is detected it is too late to reproduce. I am tended to say the incubation time is rather long.
abdullah
Postby abdullah » Thu Jul 02, 2020 5:58 pm
git commit 31b1ad874fb4750b6f6f25b494246f6ac7e61cde
