Feature: offset tool in sketcher
edi
Re: Feature: offset tool in sketcher
Postby edi » Tue Sep 22, 2020 1:05 pm
I am sorry, but I think its not a problem of the macro, but an installation problem.
Did you find the files in your computer ?
You can look for accessible python modules in the console. Just type
>>> import DraftTrackers
Hopefully somebody else using 0.19 can help us ?
Pauvres_honteux
Postby Pauvres_honteux » Tue Sep 22, 2020 1:17 pm
Running "import DraftTrackers in the Python console gives:
Python 3.6.10 (default, Jan 16 2020, 09:12:04) [GCC] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
ModuleNotFoundError: No module named 'DraftTrackers'
GeneFC
Postby GeneFC » Tue Sep 22, 2020 1:45 pm
I just checked the source master, which was updated about an hour ago. There is no longer a DraftTracker.py module in FreeCAD 0.19.
I did find it in an older version 0.18 I have on my computer, but Draft WB has been completely redesigned since then.
Gene
Rana
Postby Rana » Tue Sep 22, 2020 1:46 pm
On Latest 0.19, for DraftTrackers try :
import draftguitools.gui_trackers as DraftTrackers
and remove original DraftTrackers import.
-alex-
Postby -alex- » Tue Sep 22, 2020 3:06 pm
Thank you @edi for this great feature :D
edi wrote:
Tue Sep 01, 2020 7:45 am
I may add that some kind of continuation mode would be great: just select one edge and all subsequently connected lines are offset as well.
I will keep this idea in mind.
You could use Path_SelectLoop feature for that maybe. Just my 2 cents. (BTW it's already pretty convenient to use it by gui, as an end user I mean).
... import draftguitools.gui_trackers as DraftTrackers
It works like a charme, thank you @Rana.
About OffsetInSketcher03: works fine, sometimes overconstrained, but it's easy to autoremove redundants in sketcherWB.
Thank you again!
bleber
Postby bleber » Tue Sep 22, 2020 10:19 pm
Testing version 3.
Freecat quit when make a a offset with popup winfow that says "Inner radius becomes negativ"
Captura de pantalla_2020-09-23_00-16-46.png (11.24 KiB) Viewed 238 times
edi
Postby edi » Wed Sep 23, 2020 5:46 am
Imagine the radius of your original arc is 3. If you want to create an offset line in distance 4 at the inner side, the radius becomes -1. That is not possible, so the script stops. The outside radius would be 7.
Pauvres_honteux
Postby Pauvres_honteux » Wed Sep 23, 2020 6:34 am
... the radius becomes -1.
And that is exactly why you must add
.... if radius <=0 then trim offseted lines/curves at intersection ...
to your macro.
Pauvres_honteux
Postby Pauvres_honteux » Wed Sep 23, 2020 12:37 pm
Here's a guy who created a macro for extending lines. Have a chat with him and see if you can get forward from that chat.
Stq_Niko wrote:
Tue Jul 14, 2020 9:33 pm
Extend :
Select a cosmetic edge and run the macro :
Enter a value for the Start point (marked by a red circle on the view) and end point, then click on "OK" to execute one time and exit or use "Apply" to do the action more than one time.
edi
Postby edi » Wed Sep 23, 2020 1:28 pm
to your macro.
Thanks for that idea, I will reflect it. The problem is not the calculation of the intersection point. The problem is to keep the overview when numbering lines, arcs, edges etc. if the offset lines are less than the original lines.
