Feature: offset tool in sketcher
galou_breizh
Re: Feature: offset tool in sketcher
Postby galou_breizh » Mon Feb 22, 2021 8:04 am
edi wrote:
Wed Feb 03, 2021 8:50 am
The original macro includes many "green" comments (# comment). But macros published in the master must have only "white" comments (''' comment''').
Lines starting with '#' are comments. They have the role of describing the code to the developer.
Strings following a line with "def ..." or "class ..." are DocStrings. They have the role of describing the function to the user, as they appear in the interpreter interface, e.g. with help(fun). Strings can be defined with ', ", ''', or """. The latest two are so called multi-line strings. Modules are also documented with DocStrings.
Gaël
galou_breizh
Postby galou_breizh » Mon Feb 22, 2021 9:16 am
About the redundant constraints: for offset lines, there is a point-symmetry constraint and a point-on-line constraint for the end of the helper line. This is redundant because the point-symmetry already brings the point of the helper line on the offset line.
Gaël
Petrikas
Postby Petrikas » Sat Mar 13, 2021 4:15 pm
Awesome macro! I tested it out on FreeCAD 0.19, and it worked perfectly. Thanks!
However, just a FYI, it doesn't work at all with FreeCAD Linkstage3, here's the error:
18:07:12  Traceback (most recent call last):
  File "C:/Users/---/AppData/Roaming/FreeCAD/Macro/Offset.FCMacro", line 439, in <module>
    ex = OffsetDialog()
  File "C:/Users/---/AppData/Roaming/FreeCAD/Macro/Offset.FCMacro", line 34, in __init__
    self.tracker = DraftTrackers.lineTracker(scolor=(1,1,1),swidth=3,dotted=True)
<class 'NameError'>: name 'DraftTrackers' is not defined
I tried enabling / disabling Draft workbench to no avail. I wonder if there's a way around this? Thanks again.
Postby chrisb » Sat Mar 13, 2021 5:26 pm
If it works in master, you should ask realthunder about that.
Postby Kunda1 » Sat Mar 13, 2021 6:28 pm
    ex = OffsetDialog()
Looks like this may be missing python import of some sort. Draft workbench was re-structured by @vocx and @carlopav. That could be the issue here.
Edit: try adding
    import draftguitools.gui_trackers as DraftTrackers
to the top of the macro
Edit2: lol, the solution was this: https://forum.freecadweb.org/viewtopic. ... 70#p487199
Petrikas
Postby Petrikas » Sat Mar 13, 2021 6:30 pm
Just to contribute, I found that adding a line
if App.Version()[5].find('LinkStage3') == 0: import draftguitools.gui_trackers as DraftTrackers
accounts for LinkStage3 fork, so it works there as well, as LinkStage3 has neither 0.18 nor 0.19 in its version description, which fails to import the DraftTrackers.
Solved the problem for me.
Postby Kunda1 » Sat Mar 13, 2021 6:33 pm
Nice!
Would you like to make a PR to update that?
Petrikas
Postby Petrikas » Sat Mar 13, 2021 6:37 pm
Nice!
I have no idea how to do that :D I guess there's first time for everything. I will give it a go.
Postby Kunda1 » Sat Mar 13, 2021 6:48 pm
Nice!
Read Github
If you have issues, DM me and I'll help. ;)
edi
Postby edi » Sun Mar 14, 2021 4:51 pm
I will add the line and make a PR in the next days
