sketch behavior V18 to V19
bluebaer
Post by bluebaer »
I precieved following behavior moving a file from V18 to V19:
in V19 / incl. Link Branch:
Link branch.PNG (52.17 KiB) Viewed 3235 times
Please see test file.
Freecad complains that it can not recompute sketch because of Constraint 5.
If you delete Constraint 5 the sketches, some of them a fixed others lack one degree of freedom.
Behavior is observed with V19 and Link Branch.
Any Idea? Shouldn't V19 and V18 file fromats be lead to the same results?
Versions (not the latest):
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
OS: Ubuntu 20.04.1 LTS runnig under WSL on Win10
Version: 0.19.23756 (Git) AppImage
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
OS: Windows 10 (10.0)
Version: 2021.0205.23662 +3201 (Git)
Branch: LinkStage3
Hash: 9391fcd19568d635bb290db09f9d616e6acdc4f4
Python version: 3.6.8
Qt version: 5.12.6
OCC version: 7.4.0.beta
Test_Geo.FCStd
(273.42 KiB) Downloaded 92 times
anno
Re: sketch behavior V18 to V19
Post by anno »
I recomputed all items with 0.19.
I think thats the reason:
18:36:47  Sketcher constraint number 5 is malformed!
18:36:47  Sketch Sketch115 has malformed constraints!
18:36:47  Sketch Sketch138 has malformed constraints!
18:36:47  Sketch Sketch137 has malformed constraints!
18:36:47  Sketch Sketch136 has malformed constraints!
18:36:47  Sketch Sketch134 has malformed constraints!
18:36:47  Sketch Sketch135 has malformed constraints!
18:36:47  Sketch Sketch113 has malformed constraints!
18:36:47  Sketch Sketch111 has malformed constraints!
18:36:47  Sketch Sketch106 has malformed constraints!
18:36:56  Sketcher constraint number 5 is malformed!
18:36:56  Sketch Sketch106 has malformed constraints!
18:37:09  Sketcher constraint number 5 is malformed!
18:37:09  Sketch Sketch115 has malformed constraints!
18:37:09  Sketch Sketch138 has malformed constraints!
18:37:09  Sketch Sketch137 has malformed constraints!
18:37:09  Sketch Sketch136 has malformed constraints!
18:37:09  Sketch Sketch134 has malformed constraints!
18:37:09  Sketch Sketch135 has malformed constraints!
18:37:09  Sketch Sketch113 has malformed constraints!
18:37:09  Sketch Sketch111 has malformed constraints!
18:37:09  Sketch Sketch106 has malformed constraints!
18:37:12  Sketcher constraint number 5 is malformed!
18:37:12  Sketch Sketch115 has malformed constraints!
18:37:12  Sketch Sketch138 has malformed constraints!
18:37:12  Sketch Sketch137 has malformed constraints!
18:37:12  Sketch Sketch136 has malformed constraints!
18:37:12  Sketch Sketch134 has malformed constraints!
18:37:12  Sketch Sketch135 has malformed constraints!
18:37:12  Sketch Sketch113 has malformed constraints!
18:37:12  Sketch Sketch111 has malformed constraints!
18:37:12  Sketch Sketch106 has malformed constraints!
18:37:14  Sketcher constraint number 5 is malformed!
18:37:14  Sketch Sketch115 has malformed constraints!
18:37:14  Sketch Sketch138 has malformed constraints!
18:37:14  Sketch Sketch137 has malformed constraints!
18:37:14  Sketch Sketch136 has malformed constraints!
18:37:14  Sketch Sketch134 has malformed constraints!
18:37:14  Sketch Sketch135 has malformed constraints!
18:37:14  Sketch Sketch113 has malformed constraints!
18:37:14  Sketch Sketch111 has malformed constraints!
18:37:14  Sketch Sketch106 has malformed constraints!
Your file was already malformed or at least badly constrained in 0.18, but it wasn't detected then: Edit Basis_V4; it is fully constrained and shows no redundancies. But you can remove Constraint5 and it is still fully constrained.
So everything works as designed and you should fix your sketches.
