Allow use of circle edge to select axis in Revolution/Groove and Helix
davidosterberg
Post by davidosterberg »
PR for Revolution/Groove and Helix: https://github.com/FreeCAD/FreeCAD/pull/4451
PR for PolarPattern: https://github.com/FreeCAD/FreeCAD/pull/4469
Demo:
Demo, polar pattern:
Edit: Added a second PR for the Polar pattern version
Last edited by davidosterberg on Tue Feb 16, 2021 6:01 pm, edited 1 time in total.
LHC
Re: Allow use of circle edge to select axis in Revolution/Groove and Helix
Post by LHC »
Sweet !
I like it - a lot :D
:+1:
mendy
Post by mendy »
Aha, very nice. Took a long time for my slow brain after watching the excellent demo to finally put together that the cylinder is not on the Z axis.
Now makes good sense. Thanks.
davidosterberg
I added the same functionality to the PartDesign Polar pattern. See OP for demo. Do you think I should add this to Draft array as well? It is curious to me how non-parametric that feature is. So maybe some people want it like that? I think it could be useful for adding bolts around a circular bolt flange for example.
Jee-Bee
Post by Jee-Bee »
If you busy with PD
I can think of another situation what at least i'm missing. The possibility to add an axis in an sketch that can be used as axis reference (basically for it's own revolve / groove.
davidosterberg
Jee-Bee wrote: Tue Feb 16, 2021 9:22 pm If you busy with PD
If I understand you correctly. This is already supported in both Helix and Revolve/Groove. Just add a construction line, and it will appear in the Axis selection box.
Jee-Bee
Post by Jee-Bee »
stupid i never tried that... probably because a construction line is at least to me lower level hierarchy than (normal geometry or )axis.
that makes the implementation of a real axis feature in sketch more difficult (at least on major release that support both)
davidosterberg
Jee-Bee wrote: Wed Feb 17, 2021 7:49 am stupid i never tried that... probably because a construction line is at least to me lower level hierarchy than (normal geometry or )axis.
It is because the sketch based features in part design need a closed contour in order to do their thing. If the axis was not a construction line it would break that. Anyway, a construction line is appropriate, because the helix axis / groove axis, etc are mathematical constructions, not physical features of the model.
-alex-
Post by -alex- »
davidosterberg wrote: Tue Feb 16, 2021 6:04 pm I added the same functionality to the PartDesign Polar pattern.
Thank you so much for this great enhancement!
Definitly, +1
