bug in fcsprocket polar patten
Bsf
Post by Bsf »
Not sure if anyone else has noticed this but the fcsprocket generation has a bug in the polar patten code. One side of the gullet has the drawing in the wrong order, one side has the second arc and the joining line transposed. This is true for 0.20 24693 and 0.19 release, hope this is the correct place to post this. Regards Bsf.
Re: bug in fcsprocket polar patten
Please upload your file. Full FreeCAD infos as described in the Help forum would be beneficial too.
Bsf
Post by Bsf »
ok I think I have found the problem, it is in sprocket.py polar array section,
# rising gullet slope
w.arc(rotate(p5, alpha*n), R, 1)
w.line(rotate(p6, alpha*n))
w.arc(rotate(p7, alpha*n), E, 0)
w.arc(rotate(p8, alpha*n), F, 0)
changed it to,
w.arc(rotate(p6, alpha*n), E, 1)
w.line(rotate(p7, alpha*n))
Sprocket is now generated as expected.
hope this is helpful, Bsf.
Please place the code in <code> tags for improved readability.
C_h_o_p_i_n
Post by C_h_o_p_i_n »
Hi all,
I'd stubled across this thread: https://forum.freecadweb.org/viewtopic.php?f=22&t=44525
possibly your findings are related ... ?!
Regards,
Stefan
