Currently it's possible to trigger Std_Transform on PartDesign objects with :
* Select in the TreeView then Edit->Transform
* Python Console : 'Gui.ActiveDocument.setEdit(App.ActiveDocument.OBJECT, 1)
* In the future ? User edit mode in 'Transform' mode and double-click the object in the tree
The manipulator appears in the 3D view, it's possible to move the object in preview mode, but when validating the transformation is rejected/ignored.
In your opinion, what should be correct behavior ?
* Forbid running Std_Transform on PartDesign objects ?
* Move the AttachmentOffset of the base sketch(es) accordingly ?
* Other ?
Also it's possible to run this command on invisible objects.
What is your opinion about correct behavior ?
* Make the object visible ? Temporarily ?
* Forbid/ignore Std_Transform on invisible objects ?
* Other ?
[Annoyance] Std_Transform on PartDesign objects + invisible objects
- adrianinsaval
Re: [Annoyance] Std_Transform on PartDesign objects + invisible objects
I think it should only be allowed on those that can actually be moved, I think those are sketches datums shapebinders clones and primitives. The rest it's better to forbid, I don't think FreeCAD should move a sketch if the user is not explicitly trying to move the sketch.
I vote for thisAlso it's possible to run this command on invisible objects.
- Shalmeneser
I also found myself several times wanting just to move a feature and not been able to just Transform it and having to manipulate attachments by hand was a drag...
