Hello FC,
Hope you are all well,
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Imagine a Wire-rope hoist drum, You need the grooves to be as close to each other as possible, So I've been experimenting for over a week now on this little chestnut.
https://youtu.be/_VgqQ8U5V8w
Shows the scenario Now matter what (including a Compound) Part Boolean Cut & Part D. Boolean cut. It will not give me the 'w' groove profile obtained when Pitch = rope Dia.
Perhaps this is a bug & needs to be reported?
Boolean Helix Bug
- Shalmeneser
Re: Boolean Helix Bug
Video too small !
Pictures ?
FILE ?
Pictures ?
FILE ?
- Shalmeneser
Pitch = Radius => usual coplanarity problem
Pitch = Radius + 0.0001 => OK
- Capture du 2021-12-01 23-45-36.png (91.6 KiB) Viewed 2868 times
- test__SHALM.FCStd
- (148.34 KiB) Downloaded 50 times
No need to report. It is known, comes from OCC kernel, and I learned from other users, that at least some of the big boys have similar limitations.
Hhey thx for the reply,
I did try and upload the file, perhaps the storages is full? its a small file 4.4kb attachment error shown. I did also try that trick with the pitch +0.1mm even but for what ever reason the pitch will not generate below1.25*Rope Dia. Is there some other way I can get the file across?
- Screenshot 2021-12-02 135559.png (309.98 KiB) Viewed 2776 times
Thx Shalmenser,
Using primitives and a different train of thought I was able to produce the results shown
https://youtu.be/5Vl8jrfHrPU
Frustration there's a bug in part design I imagine the problem may be worse with Multi-start threads in 'Part Design'? -New isn't always better
I just tested: I could upload a 400K file. So no problem on this side.
