Crash on thickness tool
marioalexis
Post by marioalexis »
Step to reproduce:
Create a body.
Add additive box.
Select a face and start Thickness tool.
Press "Add Face" button.
Crash when trying to access the null pointer addAllEdgesAction in TaskDressUpParameters::onButtonRefAdd method
OS: Debian GNU/Linux bookworm/sid (KDE/plasma)
Version: 0.20.27075 +1 (Git)
Build type: Unknown
Branch: part-attachment
Hash: 47769a54af93fdfb8891c27da9cc56f59a6f7f8d
Python version: 3.9.9
Qt version: 5.15.2
OCC version: 7.5.1
Re: Crash on thickness tool
No problem here. Does it happen with any face of the six?
OS: macOS 10.16
Version: 0.20.27008 (Git)
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
marioalexis
chrisb wrote: Sat Jan 15, 2022 1:31 am No problem here. Does it happen with any face of the six?
Yes, with any face.
Here's the problem https://github.com/FreeCAD/FreeCAD/pull/5269 (don't know why with a lower revision number than yours @chrisb).
TaskFilletParameters, TaskChamferParameters, and TaskThicknessParameters inherit from TaskDressUpParameters but only the first two correctly handle the addAllEdgesAction member. On the other hand, the added changes appear to be specific to Chamfer and Fillet but no to thickness.
kisolre
Post by kisolre »
Confirrmed. This happens as soon as the "Add face" button is pressed, before any actual selection. Report window shows this:
09:06:59  Illegal storage access...
09:06:59  Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Illegal storage access! Please save your work under a new file name and restart the application!
09:06:59  The event type 3 was sent to QToolButton
Object tree:
	QToolButton (buttonRefAdd) is child of
	QWidget (PartDesignGui__TaskThicknessParameters) is child of
	QFrame is child of
	PartDesignGui::TaskThicknessParameters is child of
	Gui::TaskView::TaskPanel is child of
	QWidget (qt_scrollarea_viewport) is child of
	Gui::TaskView::TaskView is child of
	QStackedWidget (qt_tabwidget_stackedwidget) is child of
	QTabWidget (combiTab) is child of
	Gui::DockWnd::ComboView (Combo View) is child of
	QDockWidget (Combo View) is child of
	Gui::MainWindow
Pressing the "Add face" button again crashes FreeCAD. Tried other shapes - same error and crash.
Manually edited thickness support - works as expected.
Version: 0.20.27075 (Git)
Hash: 089b18f8686ac03da749b916ab304f1c13f79d21
Python version: 3.8.8
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
TheMarkster
Post by TheMarkster »
Founder
Post by wmayer »
addAllEdgesAction is a member of TaskDressUpParameters and initialized with nullptr. The function createAddAllEdgesAction() can be used to create a QAction instance and add it to the passed QListWidget.
So far createAddAllEdgesAction() is used in TaskFilletParameters and TaskChamferParameters but not in other sub-classes of TaskDressUpParameters. Thus, inside TaskDressUpParameters::onButtonRefAdd() it also must be checked if addAllEdgesAction is null or not.
git commit 2d1c083d9a
TheMarkster
wmayer wrote: Sun Jan 16, 2022 6:01 pm addAllEdgesAction is a member of TaskDressUpParameters and initialized with nullptr. The function createAddAllEdgesAction() can be used to create a QAction instance and add it to the passed QListWidget.
You beat me to it. I had exactly the same fix. I will close that PR. Thanks. I hope this fix gets in before the weekly builds are compiled.
