unexpected result with pocket
mwlandolsi
Post by mwlandolsi »
I created a part with thickness as shown below:
Screenshot from 2022-05-23 15-36-11.png (57.51 KiB) Viewed 1587 times
Then I want to cut angles with sketches. I got the following result with Length "through all".
Screenshot from 2022-05-23 15-35-53.png (69.15 KiB) Viewed 1587 times
Hope that his problem could be taken urgently by the lovely developers.
Greetings.
OS: Linux Mint 20.1 (X-Cinnamon/cinnamon)
Version: 0.20.
Branch: unknown
Hash: e1f26857346dc85f047cdb073942098e356123ba
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
Locale: English/United States (en_US) [ OS: English/United States (en_US) ]
Installed mods:
  * Design456 1560981536.0.0
  * Silk 1560981536.0.0
  * Curves 0.4.2
  * sheetmetal 0.2.49
  * OpticsWorkbench 1.0.8
  * CurvedShapes 1.0.2
Shalmeneser
Re: unexpected result with pocket
Post by Shalmeneser »
No files ? And my crystal balls are broken. URGENT !
(There are no such things as lovely developers here.)
Capture d’écran 2022-05-23 165728.jpg (36.36 KiB) Viewed 1576 times
adrianinsaval
Post by adrianinsaval »
file please
mwlandolsi
thanks for the quick answer
here is the file
test thickness pocket.FCStd.zip
(59.48 KiB) Downloaded 41 times
Please note that the initial pad is with taper angle
mwlandolsi wrote: Mon May 23, 2022 4:24 pm here is the filetest thickness pocket.FCStd.zip
Please don't zip FreeCAD files here, they are already zipped. Will have a look at the file.
The problem is in the Thickness command, which is known to be one of the most problematic commands in FreeCAD. The issue comes directly from the third party geometric kernel and there is nothing the FreeCAD developers can do about it.
Part>CheckGeometry shows the issues.
mwlandolsi
Here you mean that when the thickness is suppressed, the problem could be solved ? But I got a result with thickness and a taper angle = 0.
Screenshot from 2022-05-23 23-51-28.png (51.42 KiB) Viewed 1467 times
test thickness pocket no tapper.FCStd
(112.17 KiB) Downloaded 40 times
mwlandolsi wrote: Mon May 23, 2022 10:49 pmBut I got a result with thickness and a taper angle = 0.
No wonder, with tape angle=0 there are not complicated faces and CheckGeometry shows no errors.
