PartDesign Groove Issue (Cont.)
Re: PartDesign Groove Issue (Cont.)
Here's another fix - it seems there's a coplanar issue with the green sketch that doesn't show up until later. Moving the edge out fixes things.
Greetings to the Community!
...no problem in modeling using "Draft" for flat bases and "Part" for solidification
- SphericalGeometry2_Draft-Part.FCStd
- (33.18 KiB) Downloaded 49 times
- SphericalGeometry2_Draft-Part.png (117.19 KiB) Viewed 1633 times
Moved to PartDesign subforum
Thanks for that suggestion as well.
Using Draft for the individual lines and arcs, and then "Part-Join-Connect" and "Part-Resolve" even gives a parametric solution that works. Although I am not familiar with the Draft Workbench, and it seems to be quite a slow process.
I think we should consider this to be a Part Design bug which needs fixing.
I just tried that as well. This did not work for me. The file you attached is not cut correctly at the start of the cut.edwilliams16 wrote: ↑Tue Nov 29, 2022 11:25 pm There's clearly some numerical fragility here. If I create the red sketch at the origin and then place it position, it works.
I would normally use groove over pipe - why use the more complicated tool - but here it seems to get around some problem that is as yet not fully understood.
Obviously it worked for me.pschindler wrote: ↑Sat Dec 03, 2022 1:56 pmI just tried that as well. This did not work for me. The file you attached is not cut correctly at the start of the cut.edwilliams16 wrote: ↑Tue Nov 29, 2022 11:25 pm There's clearly some numerical fragility here. If I create the red sketch at the origin and then place it position, it works.
OS: macOS High Sierra (10.13)
Version: 0.21.30868 (Git)
Hash: b3372a52054fc34c243ac508ce67717b1476f2a9
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
Installed mods:
* CurvedShapes 1.0.4
* Curves 0.6.0
* Curves.backup1667610597.862062 0.5.12 (Disabled)
* DynamicData 2.46.0
* fasteners 0.4.23
* fcgear 1.0.0
* GDML 1.8.0
* Help 1.0.3
* lattice2 1.0.0
* MeshRemodel 1.8919.0
* offline-documentation 1.0.0-alpha
* offline-documentation.backup1668887250.997013 1.0.0-alpha (Disabled)
* Pyramids-and-Polyhedrons
* QuickMeasure-main
* toSketch 1.0.1
* Trails 2022.1.0
Mhm, maybe you did just upload an older version or something.edwilliams16 wrote: ↑Sat Dec 03, 2022 7:23 pmObviously it worked for me.pschindler wrote: ↑Sat Dec 03, 2022 1:56 pmI just tried that as well. This did not work for me. The file you attached is not cut correctly at the start of the cut.edwilliams16 wrote: ↑Tue Nov 29, 2022 11:25 pm There's clearly some numerical fragility here. If I create the red sketch at the origin and then place it position, it works.
OS: macOS High Sierra (10.13) Word size of FreeCAD: 64-bit Version: 0.21.30868 (Git) Build type: Release Branch: master Hash: b3372a52054fc34c243ac508ce67717b1476f2a9 Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3 Locale: C/Default (C) Installed mods: * CurvedShapes 1.0.4 * Curves 0.6.0 * Curves.backup1667610597.862062 0.5.12 (Disabled) * DynamicData 2.46.0 * fasteners 0.4.23 * fcgear 1.0.0 * GDML 1.8.0 * Help 1.0.3 * lattice2 1.0.0 * MeshRemodel 1.8919.0 * offline-documentation 1.0.0-alpha * offline-documentation.backup1668887250.997013 1.0.0-alpha (Disabled) * Pyramids-and-Polyhedrons * QuickMeasure-main * toSketch 1.0.1 * Trails 2022.1.0
I checked again, I now found that there is still an attachment angle of 1° in the red sketch sketch, changing that to 0° works.
Do you know what can cause this "numerical instability", and what somebody can do in general to avoid it when designing (more complex models)?
OS: Ubuntu 22.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Installed mods:
* Assembly4
* kicadStepUpMod 10.12.7
* CurvedShapes
* ParameterGroup
* sheetmetal
* Silk
* GlobalProperties
* fcgear
* fasteners
* Curves 0.3.0
When I fix the angle of the red sketch in your file, and fully constrain the red sketch it again does not work!pschindler wrote: ↑Sun Dec 04, 2022 7:45 amMhm, maybe you did just upload an older version or something.edwilliams16 wrote: ↑Sat Dec 03, 2022 7:23 pmObviously it worked for me.pschindler wrote: ↑Sat Dec 03, 2022 1:56 pmI just tried that as well. This did not work for me. The file you attached is not cut correctly at the start of the cut.edwilliams16 wrote: ↑Tue Nov 29, 2022 11:25 pm There's clearly some numerical fragility here. If I create the red sketch at the origin and then place it position, it works.
OS: Ubuntu 22.04.1 LTS (ubuntu:GNOME/ubuntu) Word size of FreeCAD: 64-bit Version: 0.20.1.29410 (Git) AppImage Build type: Release Branch: (HEAD detached at 0.20.1) Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563 Python 3.10.5, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2 Locale: English/United States (en_US) Installed mods: * Assembly4 * kicadStepUpMod 10.12.7 * CurvedShapes * ParameterGroup * sheetmetal * Silk * GlobalProperties * fcgear * fasteners * Curves 0.3.0
Although it really works with the partially constrained sketch. Really weird.
@pschindler please keep your replies succinct (no need to paste all previous replies), it's easier for others to read when you do.
