Collection of differences between original master version and realthunder
thomas-neemann
Re: Collection of differences between original version and realthunder
Post by thomas-neemann »
Cekuhnen wrote: Tue Aug 24, 2021 11:23 pm Oh so the sketching does not even work ?
it is repaired, but not yet available in the weekly version
falls ein video-link von mir schwarz und nicht anklickbar sein sollte, hier der kanal: https://www.youtube.com/channel/UCVcztV ... 03GgKekj_g
es ist auch möglich auf antworten zu klicken um den link zu sehen.
Zolko
Post by Zolko »
RT's branch has changed the syntax of the ExpressionEngine, which makes it incompatible with Assembly4 :
LCS_1.Placement * AttachmentOffset * LCS_0.Placement ^ -1
LCS_1.Placement * AttachmentOffset * LCS_0.Placement ^ (-1)
Zolko
Post by Zolko »
It is impossible to install Asm3 in the original FreeCAD when compiled from source. The Asm3 workbench doesn't even appear in the AddonManager's list of available workbenches
thomas-neemann
with mirrored sketches you work from behind in the sketch. in the original version you can only catch points by boxing them in.
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.25541 (Git) AppImage
Hash: ca043dcb6d20d70b8e24d75e810683214eecc5d4
Python version: 3.9.6
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.2
with realthunder you can select points quite normally
Version: 2021.717.24301 +3627 (Git) AppImage
Branch: LinkStage3
Hash: f63a5ea7b459872a3798027df0ff25e776524859
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
Revolve seems sometimes to fail, see https://forum.freecadweb.org/viewtopic.php?f=20&t=61714.
thomas-neemann
Spreadsheet: FreeCAD master hangs when pasting non-rectangular cell range
realthunder hangs not
viewtopic.php?p=533486#p533486
edit
multiple bodies in part design are possible in realthunder. in the master not
https://forum.freecadweb.org/viewtopic.php?f=3&t=62234
edit 2
Rectangular selection with array no longer works in realtunder
Version: 2021.911.24301 +3844 (Git) AppImage
Branch: LinkStage3
Hash: f0359ae8f443b5aadb0d26b6945b8d7a8277655f
Python version: 3.9.7
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
thomas-neemann
Re: Collection of differences between original master version and realthunder
in realtunder is this funktion: lasso element selection
https://www.youtube.com/watch?v=y82t_GFNs8w
phpBB [video]
Version: 2021.922.24301 +3888 (Git) AppImage
Branch: LinkStage3
Hash: 399863d7e37b354fea6687767605e661beace504
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
thomas-neemann
the dae import is better with the master than with the realthunder
test files https://3dwarehouse.sketchup.com/collec ... K%C3%BCche
realthunder
15:09:36 Skip 1 unsupported primitive LineSet in Mesh.
15:09:36 Traceback (most recent call last):
File "/tmp/.mount_22-sepAelUTB/usr/Mod/Arch/importDAE.py", line 170, in insert
read(filename)
File "/tmp/.mount_22-sepAelUTB/usr/Mod/Arch/importDAE.py", line 288, in read
mesh.addFacets(facets)
<class 'IndexError'>: list index out of range
Version: 2021.922.24301 +4188 (Git) AppImage
Branch: LinkDaily
Hash: 3de879c7a2ba7111cc769d98636eb6d43189459d
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
master
Version: 0.20.25844 (Git) AppImage
Hash: 1b20118dfa3fb9f127f0e4fb122701f7fcdaa9fc
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.2
edit
Problem with threaded PartDesign hole
https://forum.freecadweb.org/viewtopic. ... 27#p538558
thomas-neemann
sorting in the large parts tree gets better in realthunder than in master
https://www.youtube.com/watch?v=3goDgB1Mcg4
phpBB [video]
K0DPW
Differences between original master version and realthunder
Post by K0DPW »
This post applies to differences between original master version & realthunder version associated with installation of the two.
I downloaded "FreeCAD-asm3-Stable-Win64-Py3-Qt5-20210922.7z", the latest Realthunder version. I run FreeCAD in portable environment (from USB drive) on public computer at a library, they do not allow installs of software to their computers, but running from USB drive works for many other applications (Inkscape, etc. and the official main branch of FreeCAD); therefore getting the .7z download unpacked was a real problem, as they don't have 7z or 7zip installed on their machines. It would be nice to have these files available in other compressed formats, such as standard .zip files used industry wide. There are some .zip files listed, but they seem to be only for source code requiring compiling. But, using a private computer, finally got the Realthunder FreeCAD version download unpacked to my USB drive.
Now, when attempting to run Realthunder's version of FreeCAD, I get error message stating can't run because file "VCRUNTIME140_1.DLL" is missing - (can't find). However, said file IS present in the "bin" folder of the unpacked .7z download.
The original master version of FreeCAD (non-Realthunder) runs fine from USB drive, without this problem of "can't find .dll files that are in fact present in the "bin" folder".
Universal definition of truth applicable to ALL disciplines:
"Truth Does Not Contradict Itself"
