Assembly3 preview
realthunder
Re: Assembly3 preview
Post by realthunder »
skopjanecot wrote: Sun Dec 05, 2021 9:00 pm I get a weird bug and a crush on both Linux and macOS when I try to move whole object tree to a new body. Let me know if there is a way I can provide more information.
Upload an example file would be nice. If it causes crash, just save the file in the state before your action, and describe what's the action.
Try Assembly3 (latest version 2021.10.15) along with my custom build of FreeCAD at here.
doubters
Post by doubters »
After disconnecting the highlightness of the object, it is impossible to remove the selection from it.
OS: Ubuntu 21.10 (GNOME/gnome)
Version: 2022.111.28429 (Git) AppImage
Branch: LinkStage3
Hash: ec814c42d02f15171f9dbb7f650400c9943abfe0
Python version: 3.9.9
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Locale: C/Default (C)
Peek 2022-01-12 07-32.gif (281.01 KiB) Viewed 678 times
freedman
Post by freedman »
I am trying the latest LinkStage 2022.111
In the current FreeCAD Master I use a sketch vertex (set to non-construction) as a visible indicator in the 3D outside of Sketcher. This does not work in LinkStage, is it because LinkStage merges with a older branch? Any idea if this can be fixed?
Oh! this new LinkStage has fixed the dual monitor issue, all the panels seem to work perfectly.
Thanks
ToniTen
Post by ToniTen »
I just realized that there's a Snap for RealThunder's LinkDaily branch of FreeCAD here. I was surprised since I saw no mention of it in either this forum, or on RT's github documentation. Is this a real thing, or was it created by a 3rd party pretending to be RT?
I mean, I've got nothing against appimages, but I like the level of automatic system integration that Snaps and Flatpacks bring.
bambuko
Post by bambuko »
ToniTen wrote: Mon Jan 24, 2022 11:34 am ... Is this a real thing, or was it created by a 3rd party pretending to be RT?...
Don't know, but good find!
https://github.com/realthunder/FreeCAD_ ... 1112574529
later edit:
it's official
ToniTen
Post by ToniTen »
bambuko wrote: Mon Jan 24, 2022 12:19 pm it's official
And there was much rejoicing!
I've tested it, and well, it might be me, but it doesn't seem to be working properly yet. I can't get it to access local files (the open/save file dialogs do no appear). Snaps are tricky in that they are sandboxed and need to be given explicit access to any paths in the file system that they're supposed to access (and that's the limit of my knowledge), so it might be that it's not yet set up correctly to access /home. I googled and reached this page, and tried
snap connect freecad-realthunder:home :home
but it still does not open the open file dialog
Checking terminal output, I see this
FreeCAD 0.20, Libs: 2022.120R14555 (Git shallow)
Adding snap-specific PYTHONPATH to sys.path: /home/axis/snap/freecad-realthunder/common/.local/lib/python3.8/site-packages:/snap/freecad-realthunder/1/lib/python3.8/site-packages:/snap/freecad-realthunder/1/usr/lib/python3/dist-packages
Fontconfig warning: "/etc/fonts/conf.avail/53-monospace-lcd-filter.conf", line 10: Having multiple values in <test> isn't supported and may not work as expected
connect failed: No such file or directory
which might or might not be relevant.
I've reached the limits of my knowledge on the black magic required to make snaps work.
BTW, I'm on ubuntu 18.04, snapd 2.53.4.
