I'm referring to this page:Zolko wrote: ....
https://github.com/Zolko-123/FreeCAD_Ex ... /README.md
Something is changed, as If I do the passages in:
Document "bearing"
But with Assembly4 0.12.4 when importing the STEP file, I obtain already and App::Part, but now I can't get to follow the example, as if I select the "Bearing" object and the edge of the newly created part Bearing_20x37x9, that I have moved under the main part, I obtain:
PartDesign::CoordinateSystem: Link(s) to object(s) 'Part__Feature015' go out of the allowed scope 'LCS_1'. Instead, the linked object(s) reside within 'Bearing'.
This the resulting file with the two LCS added to "Bearing" leaving Bearing_20x37x9 as a separate part, and this gave no error, but I doubt it is correct.
Any help would be appreciated.
Regards
Carlo D.
EDIT: forgotten to post proper FC info. Sorry.
OS: Artix Linux (openbox)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.10.5, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: Italian/Italy (it_IT)
Installed mods:
* Assembly4 0.12.4
* toSketch 1.0.1
* Curves 0.5.8
