Test Request: Part Design Workflow
ickby
Postby ickby » Tue Jun 02, 2015 3:43 pm
tanderson, deepsoic and myself (and of course jreihnlaender with the initial implementation) have put quite some work into the upcoming part design workbench and I would now like some feedback on the current state of the workflow. Apart from the loft feature, which is still missing, I consider the work-flow pretty much done, but I have the feeling that I need some fresh eyes. I'm sure there are many obvious thing I just don't recognize anymore. Hence I would like to hear your feedback. It is important to get this now as once we have started with the document migration tool all tool properties etc. are fixed, so big changes need to happen now. (and I have time over the weekend and want to work on finalizing the workbench)
* Are there any obvious bugs?
* Is the workflow intuitive or do you have no idea how to handle the new part design?
* Any counterintuitive things, workflows?
* Any regressions to current part design modeling?
Please note that the transformation is not yet done, therefore this is known and should be considered:
*Documents done with any other versions may not be loaded or at least wont be transformed to the new part design structure
*Part tools don't recognize the active part object
*documents saved now may not be editable in future versions
I would highly value input! Here you find the code:
https://github.com/blobfish/FreeCAD_sf_ ... baseMaster
The compiled windows version is provided by sgrogan, thanks!
Stefan
EDIT: Reported Issues
- Crash reports: drei [fixed] triplus [fixed] bejant [fixed] Fat-Zer [fixed second one]manderson [fixed]
- Hole feature is not ported [fixed]
- Shaft Wizard is not ported[fixed]
- Pipe icon in the pipe task dialog is not available [fixed]
- part design unit test fails
- New part command is missing Form the task Dialog when opening a New file [fixed]
- Creating of part when switching to part design is too automatic and not very freecadish
- Primitive handling needs updates cox
- Toolbar handling and placing in sketcher workbench should be persistent [can't reproduce any inconsistency]
- Primitive task dialog ok/cancel handling is wrong for bad references [fixed]
- Sketch highlighting does not always work when selected from the tree [fixed]
- Origin (and planes/lines inside) should not be deletable [fixed]
- deleting part or body shoud delete all subcomponents [fixed]
- Add Body / Part tools should omit the word "feature" [fixed]
- Pipe tool orientation is sometimes wrong manderson [fixed]
- sketch placement sometime is broken. kwahoo [fixed]
drei
Re: Test Request: Part Design Workflow
Postby drei » Tue Jun 02, 2015 8:02 pm
ickby,
I'm getting compiler error when running
make -j4
Attached is the entire make log, though I'll post below the most prominent warnings.
Summary:
  • Warnings about needing to set compiler to use c++11 flags. Any idea how and where I can do that?
  • Error at 26%
    [ 26%] Generating moc_DlgCheckableMessageBox.cpp
    /home/isaac/Programs/FreeCAD/part-design-src/src/Gui/DlgCheckableMessageBox.h:54: Warning: Property declaration prefEntry has no READ accessor function. The property will be invalid.
  • Warning at 35%
    [ 35%] Building CXX object src/Gui/CMakeFiles/FreeCADGui.dir/Application.cpp.o
    In file included from /usr/include/eigen3/Eigen/Core:373:0,
                     from /usr/include/eigen3/Eigen/LeastSquares:11,
                     from /home/isaac/Programs/FreeCAD/part-design-src/src/Mod/Mesh/App/Core/Approximation.cpp:59:
    /usr/include/eigen3/Eigen/Eigen2Support:20:2: warning: #warning "Eigen2 support is deprecated in Eigen 3.2.x and it will be removed in Eigen 3.3. (Define EIGEN_NO_EIGEN2_DEPRECATED_WARNING to disable this warning)" [-Wcpp]
  • Warning at 36%
    [ 36%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/FeaturePartSpline.cpp.o
    /home/isaac/Programs/FreeCAD/part-design-src/src/Gui/Document.cpp: In member function ‘void Gui::Document::createView(const Base::Type&)’:
    /home/isaac/Programs/FreeCAD/part-design-src/src/Gui/Document.cpp:990:40: warning: range-based ‘for’ loops only available with -std=c++11 or -std=gnu++11
             for(App::DocumentObject* obj : child_vps)
  • Warning at 45%
    [ 45%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/CylinderPyImp.cpp.o
    /home/isaac/Programs/FreeCAD/part-design-src/src/Gui/CommandDoc.cpp: In member function ‘virtual void StdCmdDelete::activated(int)’:
    /home/isaac/Programs/FreeCAD/part-design-src/src/Gui/CommandDoc.cpp:1089:38: error:
    ISO C++ forbids declaration of ‘currentLabel’ with no type [-fpermissive]
                         for (const auto &currentLabel : affectedLabels)
    /home/isaac/Programs/FreeCAD/part-design-src/src/Gui/CommandDoc.cpp:1089:53: warning: range-based ‘for’ loops only available with -std=c++11 or -std=gnu++11
    src/Gui/CMakeFiles/FreeCADGui.dir/build.make:1745: recipe for target 'src/Gui/CMakeFiles/FreeCADGui.dir/CommandDoc.cpp.o' failed
    make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/CommandDoc.cpp.o] Error 1
    make[2]: *** Waiting for unfinished jobs....
    [ 45%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/SpherePyImp.cpp.o
    CMakeFiles/Makefile2:3127: recipe for target 'src/Gui/CMakeFiles/FreeCADGui.dir/all' failed
    make[1]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/all] Error 2
    make[1]: *** Waiting for unfinished jobs....
  • Fails to compile at 49% with the following message:
    Linking CXX shared library ../../../../Mod/Part/Part.so
    [ 49%] Built target Part
    Makefile:116: recipe for target 'all' failed
    make: *** [all] Error 2
Current cmake flags:
cmake ../part-design-src -DPYTHON_EXECUTABLE=/usr/bin/python2 -DFREECAD_USE_EXTERNAL_PIVY=1 -DBUILD_FEM=1 -DBUILD_CAM=0 -DBUILD_COMPLETE=0 -DBUILD_IMAGE=1 -DBUILD_INSPECTION=0 -DBUILD_OPENSCAD=0 -DBUILD_PLOT=1 -DBUILD_POINTS=0 -DBUILD_REVERSEENGINEERING=0 -DBUILD_SHIP=0 -DBUILD_ROBOT=0 -DBUILD_SPREADSHEET=1 -DBUILD_ASSEMBLY=0 -DCMAKE_BUILD_TYPE=Debug -DFREECAD_USE_3DCONNEXION=0 -DBUILD_FEM_NETGEN=0 -
My system:
                  .o+`                 isaac@Arch
                 `ooo/                 OS: Arch Linux
                `+oooo:                Kernel: x86_64 Linux 4.0.4-2-ARCH
               `+oooooo:               Uptime: 3h 1m
               -+oooooo+:              Packages: 849
             `/:-:++oooo+:             Shell: bash 4.3.39
            `/++++/+++++++:            Resolution: 1366x768
           `/++++++++++++++:           DE: KDE5
          `/+++ooooooooooooo/`         WM: KWin
         ./ooosssso++osssssso+`        GTK Theme: Orion [GTK2], Orion [GTK3]
        .oossssso-````/ossssss+`       Icon Theme: breeze
       -osssssso.      :ssssssso.      Font: Montserrat Regular
      :osssssss/        osssso+++.     CPU: Intel Core i5-3337U CPU @ 2.7GHz
     /ossssssss/        +ssssooo/-     RAM: 3404MB / 7871MB
   `/ossssso+/:-        -:/+osssso+-
  `+sso+:-`                 `.-/+oso:
Regards,
Isaac
make_error_log.txt.zip
(67.65 KiB) Downloaded 90 times
ickby
Postby ickby » Tue Jun 02, 2015 8:13 pm
ahh thanks for reporting, totally forgot about that one! I have pushed a fix, it should work now
rockn
Postby rockn » Tue Jun 02, 2015 8:20 pm
I managed to compile on Ubuntu 14.04 64 bits :
In cmake-gui I have set std=c++0x to CMAKE_CXX_FLAGS
And I enable Assembly module.
I have some warnings like Drei.
Excuse my noob question, where can I get the logs ? the history of terminal don't have all the warning.
Going to try new Part Design WB :)
Formations et tutoriels FreeCAD en Français, soutenez moi : https://www.tipeee.com/formations-freecad
drei
Postby drei » Tue Jun 02, 2015 8:45 pm
New errors appear with
make -j4
I changed cmake flags to
cmake ../part-design-src -DPYTHON_EXECUTABLE=/usr/bin/python2 -DFREECAD_USE_EXTERNAL_PIVY=1 -DBUILD_FEM=1 -DBUILD_CAM=0 -DBUILD_COMPLETE=0 -DBUILD_IMAGE=1 -DBUILD_INSPECTION=0 -DBUILD_OPENSCAD=0 -DBUILD_PLOT=1 -DBUILD_POINTS=0 -DBUILD_REVERSEENGINEERING=0 -DBUILD_SHIP=0 -DBUILD_ROBOT=0 -DBUILD_SPREADSHEET=1 -DBUILD_ASSEMBLY=1 -DCMAKE_BUILD_TYPE=Debug -DFREECAD_USE_3DCONNEXION=0 -DBUILD_FEM_NETGEN=0
Summary:
  • Error at 47%
    [ 47%] Built target MeshPart
    Linking CXX shared library ../../../../Mod/Import/Import.so
    /usr/bin/ld: cannot find -lAssembly
    src/Mod/Import/App/CMakeFiles/Import.dir/build.make:299: recipe for target 'Mod/Import/Import.so' failed
    make[2]: *** [Mod/Import/Import.so] Error 1
    CMakeFiles/Makefile2:2622: recipe for target 'src/Mod/Import/App/CMakeFiles/Import.dir/all' failed
    make[1]: *** [src/Mod/Import/App/CMakeFiles/Import.dir/all] Error 2
  • Failure at 68%
    Linking CXX shared library ../../lib/libFreeCADGui.so
    [ 68%] Built target FreeCADGui
These were the only warnings that appeared, I'll do a
make clean
and then I'll attempt to do it again. Are there any specific workbenches that the new PartDesign relies on?
ickby
Postby ickby » Tue Jun 02, 2015 8:47 pm
Not realy, only Part and Sketcher! It seem you build assembly workbench, maybe try disabling that as it is useless anyway.
DeepSOIC
Postby DeepSOIC » Tue Jun 02, 2015 8:48 pm
word censored, I'm late with transferring datum planes to my new mapping functionality. Anyway, don't wait for me. I will have to make a porting tool, then.
drei
Postby drei » Tue Jun 02, 2015 9:20 pm
ickby,
New errors, attached is the entire log.
cmake flags:
Summary:
  • Warning and note at 15%
    [ 15%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Quantity.cpp.o
    In file included from /home/isaac/Programs/FreeCAD/part-design-src/src/Base/Quantity.cpp:298:0:
    QuantityLexer.c:112:0: warning: "YY_NULL" redefined
    In file included from /home/isaac/Programs/FreeCAD/part-design-src/src/Base/Quantity.cpp:294:0:
    QuantityParser.c:84:0: note: this is the location of the previous definition
  • Warning at 22%
    [ 22%] Building CXX object src/App/CMakeFiles/FreeCADApp.dir/PropertyFile.cpp.o
    /home/isaac/Programs/FreeCAD/part-design-src/src/3rdParty/salomesmesh/src/SMESH/SMESH_MeshEditor.cpp: In member function ‘SMESH_MeshEditor::Sew_Error SMESH_MeshEditor::SewFreeBorder(const SMDS_MeshNode*, const SMDS_MeshNode*, const SMDS_MeshNode*, const SMDS_MeshNode*, const SMDS_MeshNode*, const SMDS_MeshNode*, bool, bool, bool)’:
    /home/isaac/Programs/FreeCAD/part-design-src/src/3rdParty/salomesmesh/src/SMESH/SMESH_MeshEditor.cpp:6013:35: warning: narrowing conversion of ‘nSide[0].std::list<_Tp, _Alloc>::size<const SMDS_MeshNode*, std::allocator<const SMDS_MeshNode*> >()’ from
    std::list<const SMDS_MeshNode*>::size_type {aka long unsigned int}’ to ‘int’ inside { } [-Wnarrowing]
       int nbNodes[]  = { nSide[0].size(), nSide[1].size() };
    /home/isaac/Programs/FreeCAD/part-design-src/src/3rdParty/salomesmesh/src/SMESH/SMESH_MeshEditor.cpp:6013:52: warning: narrowing conversion of ‘nSide[1].std::list<_Tp, _Alloc>::size<const SMDS_MeshNode*, std::allocator<const SMDS_MeshNode*> >()’ from
  • Warning at 25%
    [ 25%] Generating moc_DlgCheckableMessageBox.cpp
  • Warning at 36% about Eigen
    [ 36%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Core/Approximation.cpp.o
  • Error at 74%
    [ 74%] Building CXX object src/Mod/Fem/App/CMakeFiles/Fem.dir/FemConstraint.cpp.o
  • Failure at 75%
    Linking CXX shared library ../../../../Mod/Spreadsheet/SpreadsheetGui.so
    [ 75%] Built target SpreadsheetGui
make_error_log02.txt.zip
(106.48 KiB) Downloaded 62 times
drei
Postby drei » Tue Jun 02, 2015 9:47 pm
New try,
what I did:
make clean
cmake ../part-design-src -DPYTHON_EXECUTABLE=/usr/bin/python2 -DFREECAD_USE_EXTERNAL_PIVY=1 -DBUILD_FEM=0 -DBUILD_CAM=0 -DBUILD_COMPLETE=0 -DBUILD_IMAGE=1 -DBUILD_INSPECTION=0 -DBUILD_OPENSCAD=0 -DBUILD_PLOT=0 -DBUILD_POINTS=0 -DBUILD_REVERSEENGINEERING=0 -DBUILD_SHIP=0 -DBUILD_ROBOT=0 -DBUILD_SPREADSHEET=0 -DBUILD_ASSEMBLY=0 -DCMAKE_BUILD_TYPE=Debug -DFREECAD_USE_3DCONNEXION=0 -DBUILD_FEM_NETGEN=0
make -j4 >> log.txt
Summary:
It seems there ae problems with the Import.so file and some searches for -lAssembly (no idea what this is).
And for some weird reason, it still builds the Spreadsheet module even though I set tha flag off.
make_error_log03.txt.zip
(101.02 KiB) Downloaded 67 times
ickby
Postby ickby » Wed Jun 03, 2015 5:02 am
Thanks for posting the log, this way I was able to find a dependency of the import module on the assembly workbench which was not very well handled in the cmake files. I did now disable that dependency, as the assembly workbench is useless. Please try again.
