I pushed some commits to the rebaseMaster branch, one is a fix for this bug. Note that I also rebased the code to master.drei wrote:Got a crash today (SIGSEV) , not sure if I did something I should not do.
Procedure:
- Start FreeCAD
- Create new Document
- Switch to Part Design Workbench
- Create Part object (yellow tag) from the Combo View
- Select the Part Object in the Tree View
- Add a body to the Part object
- Delete the body
- Add another body
Test Request: Part Design Workflow
Re: Test Request: Part Design Workflow
Thanks ickby,
I get a single errror on Win VC12,x64, release
Error 2 error C1189: #error : Deprecated: use SoMultiTextureEnabledElement instead C:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\Inventor\elements\SoGLTexture3EnabledElement.h 36 1 coin
"fight the good fight"
thanks for testing sgrogan. But I can't imagine what this error should be, I did not do anything with coin. Can you please post the whole bug report? Also it may be good idea to try a full rebuild, as a large rebase and many changes sometimes breaks the incremental builds.sgrogan wrote:Thanks ickby,
I get a single errror on Win VC12,x64, releaseCode: Select all
Some hack trying to compile the wrong branchickby wrote:But I can't imagine what this error should be
The real errors for the rebaseMaster branch VS2013 x64 release
Error 28 error C3083: '__cxx11': the symbol to the left of a '::' must be a type c:\users\sim\documents\sw_projects\amm1\src\mod\partdesign\gui\ViewProviderBody.h 62 1 PartDesignGui
Error 29 error C3083: '__cxx11': the symbol to the left of a '::' must be a type c:\users\sim\documents\sw_projects\amm1\src\mod\partdesign\gui\ViewProviderBody.h 62 1 PartDesignGui
Error 30 error C3083: '__cxx11': the symbol to the left of a '::' must be a type C:\Users\sim\Documents\SW_Projects\AMM1\src\Mod\PartDesign\Gui\ViewProviderBody.cpp 115 1 PartDesignGui
Error 31 error C3083: '__cxx11': the symbol to the left of a '::' must be a type c:\users\sim\documents\sw_projects\amm1\src\mod\partdesign\gui\ViewProviderBody.h 62 1 PartDesignGui
Isn't this one of the error messages you get when trying to build pivy with Coin4.x? Does your branch still have the pivy sources included?ickby wrote:thanks for testing sgrogan. But I can't imagine what this error should be, I did not do anything with coin. Can you please post the whole bug report? Also it may be good idea to try a full rebuild, as a large rebase and many changes sometimes breaks the incremental builds.sgrogan wrote:Thanks ickby,
@ickby, are you sure this is proper C++11 code?
To me it looks like some gcc specific extension. And what would be the difference between std::__cxx11::string and std::string, btw?
virtual void setOverrideMode(const std::__cxx11::string& mode);
ah I see, this is some auto completion from my IDE... I did not notice this while developing. This is indeed some standart library implementation dependend detail, it should of course be std::string only.
I will fix it this afternoon.
Yes, this is the case. I tried to compile the assemblyMergeMaster1 branch. It still has the Cmake flage to USE_EXNERNAL_PIVY which I missed.wmayer wrote: Isn't this one of the error messages you get when trying to build pivy with Coin4.x? Does your branch still have the pivy sources included?
The rebaseMaster branch still contains the PIVY source though, although USE_EXTERNAL_PIVY is not necessary. https://github.com/blobfish/FreeCAD_sf_ ... c/3rdParty
Using std::string, I now get a linker error
Error 30 error LNK2019: unresolved external symbol "public: static class Base::Type __cdecl Gui::ViewProviderOriginFeature::getClassTypeId(void)" (?getClassTypeId@ViewProviderOriginFeature@Gui@@SA?AVType@Base@@XZ) referenced in function "protected: void __cdecl PartDesignGui::ViewProviderBody::slotChangedObjectGui(class Gui::ViewProviderDocumentObject const &,class App::Property const &)" (?slotChangedObjectGui@ViewProviderBody@PartDesignGui@@IEAAXAEBVViewProviderDocumentObject@Gui@@AEBVProperty@App@@@Z) C:\Users\sim\Documents\SW_Projects\rebaseMaster2-build\src\Mod\PartDesign\Gui\ViewProviderBody.obj PartDesignGui
Error 31 error LNK1120: 1 unresolved externals C:\Users\sim\Documents\SW_Projects\rebaseMaster2-build\Mod\PartDesign\PartDesignGui.pyd PartDesignGui
https://github.com/blobfish/FreeCAD_sf_ ... nFeature.h lacks of the "GuiExport" export macro.
