Assembly pattern
Jee-Bee
Assembly pattern
Postby Jee-Bee » Fri Jun 26, 2015 9:42 am
I have a feature request for assembly mode.
I think it would be very handy when there is the possibility to create Patterns in assembly based on features done in part mode.
Sound difficult maybe but saves lot of work.
Let say you have a set of holes(8 holes or so) created with a pattern in part mode. In every hole there have a bold with a washer and a nut placed.
You quite busy with every time add bold, washer and nut.
If you can add a bold washer and nut on one hole and pattern them just by following the pattern allready is it saves quite amount of work
DeepSOIC
Re: Assembly pattern
Postby DeepSOIC » Fri Jun 26, 2015 12:28 pm
I sometimes use patharray for such purposes. But it is not always good enough, because the spacing is not arbitrary.
DeepSOIC
Postby DeepSOIC » Fri Jun 26, 2015 12:37 pm
example: (uses sketch-to-sketch links)
assembling-with-patharray.FCStd
(12.34 KiB) Downloaded 57 times
Positions of pins are controlled by Sketch (circles). Not superb, but better than having to place stuff manually.
Made with the following (but will work when opened in regular FreeCAD just as well)
OS: Windows 8.1
Version: 0.16.4905 +21 (Git)
Branch: origin/FreeCAD-DeepSOIC,master-mirror
Hash: 3064e7e0beabca8cbf599ae96c5173c55d37f046
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
Jee-Bee
Postby Jee-Bee » Fri Jun 26, 2015 2:47 pm
I don't know how you do it but i can't link the geometry of the circles to the lines…
Yeah faster when you do this than manually but not handy when you want a part list.
Something different i disabled a few WB's. And my arch WB lost some of his funcionality. I would be nice when i do that a messege apears that other WB's lost functionality...
DeepSOIC
Postby DeepSOIC » Fri Jun 26, 2015 6:07 pm
Jee-Bee wrote:I don't know how you do it but i can't link the geometry of the circles to the lines…
I use my own FreeCAD branch for this. It is possible to do with regular FreeCAD, but it is tricky.
Try:
1. Python: App.ActiveDocument.Sketch001.Support=(App.ActiveDocument.Sketch,"Face1")
2. Edit Sketch001, link in the required stuff
3. Reorient Sketch001 to detach it from the fake support.
Jee-Bee
Postby Jee-Bee » Sat Jun 27, 2015 9:19 am
Your approach is more on part level in my feeling with simple forms. When more complex screws and sets of nut washer and bold it is quite difficult i think...
Is this something that could add to a feature list for future implementation.
That would be very nice.
It is of course possible that i'm the only one who sees a screw/ bolt/ nut/... as a part and not as a part of a part….
Jee-Bee
Postby Jee-Bee » Mon Jun 29, 2015 8:06 am
I tried but i can't use the circles. Then use external geometry i can't select them..
Or do you that some way around..
severoraz
Postby severoraz » Thu Jul 11, 2019 3:58 pm
This is however a valid feature request, in my opinion. Assembly patterns are very useful. Does anybody have a reason why this should not be a feature?
DeepSOIC
Postby DeepSOIC » Thu Jul 11, 2019 4:44 pm
Check out Draft PointArray. If you want more functionality like that, check out Lattice2 add-on workbench.
dan-miel
Postby dan-miel » Fri Jul 12, 2019 1:58 am
I think it is valid. It is also a bit tricky to accomplish.
Even though I normally think of a screw/nut/bolt as a subassembly. In this case I think the screw/ bolt/ nut/ would need to be inserted as parts in the assembly in order to make the BOM count correct.
Dan
