DeepSOIC: Can you see the reason that our activecontainer still fails to go to the parent of the current container and let us create the new body?
Also, I have just tried to rebase my ActiveContainer branch to the current master, but the rebase conflicts when the system applies my commit "PartDesign: port to use ActiveContainer" in Utils.cpp
PartDesign::Body *getBody(bool messageIfNot)
<<<<<<< d36161725348f7998d8f9fb36ced0a4538a90e87
PartDesign::Body * activeBody = nullptr;
Gui::MDIView *activeView = Gui::Application::Instance->activeView();
bool singleBodyDocument = activeView->getAppDocument()->
countObjectsOfType(PartDesign::Body::getClassTypeId()) == 1;
if (activeView) {
if ( PartDesignGui::assureModernWorkflow ( activeView->getAppDocument() ) ) {
activeBody = activeView->getActiveObject<PartDesign::Body*>(PDBODYKEY);
if (!activeBody && singleBodyDocument) {
Gui::Command::doCommand( Gui::Command::Gui,
"Gui.activeView().setActiveObject('pdbody',App.ActiveDocument.findObjects('PartDesign::Body')[0])");
return activeBody;
if (!activeBody && messageIfNot) {
QMessageBox::warning(Gui::getMainWindow(), QObject::tr("No active Body"),
QObject::tr("In order to use PartDesign you need an active Body object in the document. "
"Please make one active (double click) or create one.\n\nIf you have a legacy document "
"with PartDesign objects without Body, use the transfer function in "
"PartDesign to put them into a Body."
PartDesign::Body* activeBody = PartDesign::Body::activeBody();
if ( PartDesignGui::assureModernWorkflow ( App::GetApplication().getActiveDocument() ) ) {
"Please make one active (double click) or create one. If you have a legacy document "
return activeBody;
and CommandBody.cpp:.
void CmdPartDesignBody::activated(int iMsg)
Q_UNUSED(iMsg);
if ( !PartDesignGui::assureModernWorkflow( getDocument() ) )
return;
App::Part *actPart = PartDesignGui::getActivePart ();
App::Part* partOfBaseFeature = nullptr;
std::vector<App::DocumentObject*> features =
getSelection().getObjectsOfType(Part::Feature::getClassTypeId());
App::DocumentObject* baseFeature = nullptr;
bool viewAll = features.empty();
if (!features.empty()) {
if (features.size() == 1) {
baseFeature = features[0];
if ( baseFeature->isDerivedFrom ( PartDesign::Feature::getClassTypeId() ) &&
PartDesign::Body::findBodyOf ( baseFeature ) ) {
// Prevent creating bodies based on features already belonging to other bodies
QMessageBox::warning(Gui::getMainWindow(), QObject::tr("Bad base feature"),
QObject::tr("Body can't be based on a PartDesign feature."));
else if (PartDesign::Body::findBodyOf ( baseFeature )){
QObject::tr("%1 already belongs to a body, can't use it as base feature for another body.")
.arg(QString::fromUtf8(baseFeature->Label.getValue())));
else if ( baseFeature->isDerivedFrom ( Part::BodyBase::getClassTypeId() ) ) {
// Prevent creating bodies based on bodies
QObject::tr("Body can't be based on another body."));
else {
partOfBaseFeature = App::Part::getPartOfObject(baseFeature);
if (partOfBaseFeature != 0 && partOfBaseFeature != actPart){
//prevent cross-part mess
QObject::tr("Base feature (%1) belongs to other part.")
} else {
QObject::tr("Body may be based no more than on one feature."));
return;
openCommand("Add a Body");
std::string bodyName = getUniqueObjectName("Body");
// add the Body feature itself, and make it active
doCommand(Doc,"App.activeDocument().addObject('PartDesign::Body','%s')", bodyName.c_str());
if (baseFeature) {
if (partOfBaseFeature){
//withdraw base feature from Part, otherwise visibility mandess results
doCommand(Doc,"App.activeDocument().%s.removeObject(App.activeDocument().%s)",
partOfBaseFeature->getNameInDocument(), baseFeature->getNameInDocument());
doCommand(Doc,"App.activeDocument().%s.BaseFeature = App.activeDocument().%s",
bodyName.c_str(), baseFeature->getNameInDocument());
addModule(Gui,"PartDesignGui"); // import the Gui module only once a session
doCommand(Gui::Command::Gui, "Gui.activeView().setActiveObject('%s', App.activeDocument().%s)",
PDBODYKEY, bodyName.c_str());
doCommand(Gui::Command::Gui, "App.ActiveDocument.ActiveContainer = '%s'",
bodyName.c_str());
// Make the "Create sketch" prompt appear in the task panel
doCommand(Gui,"Gui.Selection.clearSelection()");
doCommand(Gui,"Gui.Selection.addSelection(App.ActiveDocument.%s)", bodyName.c_str());
// The method 'SoCamera::viewBoundingBox' is still declared as protected in Coin3d versions
// older than 4.0.
#if COIN_MAJOR_VERSION >= 4
// if no part feature was there then auto-adjust the camera
if (viewAll) {
Gui::Document* doc = Gui::Application::Instance->getDocument(getDocument());
Gui::View3DInventor* view = doc ? qobject_cast<Gui::View3DInventor*>(doc->getActiveView()) : nullptr;
if (view) {
SoCamera* camera = view->getViewer()->getCamera();
SbViewportRegion vpregion = view->getViewer()->getViewportRegion();
float aspectratio = vpregion.getViewportAspectRatio();
float size = Gui::ViewProviderOrigin::defaultSize();
SbBox3f bbox;
bbox.setBounds(-size,-size,-size,size,size,size);
camera->viewBoundingBox(bbox, aspectratio, 1.0f);
#endif
updateActive();
Apparently, the conflict is due to the introduction of the ActiveView in the master branch, and we somehow need to tie ActiveContainer to the ActiveVew.
Last time, you said you will be back in August, and it is already close to September, are you ready to have a look?
