Links
ickby
Re: Links
Postby ickby » Sun Jun 18, 2017 7:00 am
Your branch does currently not compile, there is a missing file:
/home/stefan/Projects/FreeCAD_sf_master/src/Gui/ViewProviderLink.cpp:47:32: fatal error: ViewProviderLinkPy.h:
realthunder
Re: Links
Postby realthunder » Sun Jun 18, 2017 8:54 am
Fixed. That header is not needed. I forget to remove it.
realthunder
Re: Links
Postby realthunder » Sun Jun 18, 2017 8:56 am
Jee-Bee wrote:
Sat Jun 17, 2017 7:50 pm
why not just add it to Assembly 2?
I intend to, which is why I said it will be a fork of assembly2. It's just that the modification is going to be significant. And I doubt it is feasible to be backward compatible with project created by the old assembly2.
Jee-Bee
Re: Links
Postby Jee-Bee » Sun Jun 18, 2017 10:46 am
thanks for explaining
Jee-Bee
Re: Links
Postby Jee-Bee » Fri Jul 28, 2017 3:08 pm
I saw the links is not yet added to master. is this still the planning? I hope it will not be pulled back
realthunder
Re: Links
Postby realthunder » Fri Jul 28, 2017 4:03 pm
I have divided my branches into three large patch set against the upstream master, and I've just started submitting the first patch set two weeks ago. I'd expect it to take at least a few months to get through, if at all.
Jee-Bee
Re: Links
Postby Jee-Bee » Fri Jul 28, 2017 4:28 pm
I hope so!! I think FreeCAD is stronger with this as first and as second it looks like a large amount of work!!
