Assembly3 preview
easyw-fc
Re: Assembly3 preview
Post by easyw-fc »
Mark Szlazak wrote: Fri Jun 15, 2018 3:31 pm I have Creo 4.0 on my system but have not done this before(Sorry lost track in this thread). If you point me to the file and walk me through this on Creo i can attempt it Monday.
This is the 1GB file to test by ProE:
Barreleye G2 3D STP-20170310-detailed zipped
brave tester are welcome! :D
Mark Szlazak
Post by Mark Szlazak »
easyw-fc wrote: Fri Jun 15, 2018 3:42 pm
Thanks. You also want some measurements done on this in Creo. How do I do those. I guess you want my machine info as well.
easyw-fc
Post by easyw-fc »
Mark Szlazak wrote: Fri Jun 15, 2018 5:34 pm Thanks. You also want some measurements done on this in Creo. How do I do those. I guess you want my machine info as well.
If possible:
- approx loading time
- rotation handling responsibility
- your processor, GPU, memory details
Thx
easyw-fc
Post by easyw-fc »
realthunder wrote: Wed Jun 13, 2018 7:42 am New bug fix version released, with the above mentioned new settings.
New performance with the 200MB model ... live screencast! :D
Mark Szlazak
easyw-fc wrote: Fri Jun 15, 2018 6:43 pm
If possible:
Thx
Ok but where do I get the first two measurements from?
easyw-fc
Post by easyw-fc »
Mark Szlazak wrote: Fri Jun 15, 2018 9:09 pm
If possible:
Thx
1) loading time... I don't know Creo .. if it is not scriptable, the only way is to get start time, click 'load' the model and check time by time if the model is loaded ;)
2) handling responsibility is also a perceiving feedback... you can see my previous post to watch what can be done now in FC
https://forum.freecadweb.org/download/file.php?id=61160
realthunder
Post by realthunder »
freecad-heini-1 wrote: Fri Jun 15, 2018 8:33 am There is one thing that is sometimes really slow. The measurement tool for distance and the FCInfo macro to calculate the part volume and weight. If you are intested, I could send you some customer files (top-secret) via PM.
I can certainly take a loo, but not now. I'll be concentrating on the upstream merging stuff now, already behind schedule.
realthunder
New minor feature release
Three new options added to STEP importer.
ShowProgress: whether to show progress during import stage.
ReduceObjects: whenever there are instances of the same object within the same hierarchy, replace them with a single Link array. This option works particularly well with the PCB models posted by easyw-fc, because all the duplicated pads are nicely grouped, and the import time can be cut down by half. However, it will slightly change the hierarchy (although, I think the hierarchy works better this way), which is why this option is off by default.
ExpandCompound: expand compound shape if it contains multiple solids. I suspect this is the critical option to DISABLE when loading large and geometrically complex models.
Anyway, when I tried the 1G monster file with ReduceObjects ON, and ExpandCompound OFF, I was able to load the file in only about 1000 seconds. And import time is around 300 seconds. But my graphics card is completely overwhelmed, which takes almost 20 seconds to render one frame. Those of you have a proper graphics card can give it a try.
Edit: forgot to mention. I do have 16GB ram, and FC consumed more than 6GB at the peak for this file. So I think 8GB machines will have a hard time with this.
easyw-fc
Post by easyw-fc »
realthunder wrote: Sun Jun 17, 2018 1:04 pm New minor feature release
Testing result with a 16GB RAM, GTX965M GPU card and i7 quad cores 8 threads (it is a gaming PC, good for CAD ;) ):
Full loading time with the suggested options (ReduceObjects ON, and ExpandCompound OFF): 1355sec
and here the responsiveness
I'm impressed! :shock: :D 8-)
EDIT:
should the 'Enable STEP Compound Merge' option still be needed/used?
EDIT2
It can be useful for old importer compatibility
Mark Szlazak
How did you get the name "realthunder" :D
Good job!
