Assembly3 preview
Re: Assembly3 preview
Hi Rene. I had the same problem with the asm3 Windows version, adding some workbenches to Mod made the ASM3 WB disappear. Try to move the workbenches in Mod to a backup folder somewhere else. Yet, do no ask me why ...
Since I deleted the config files, I see an error:
Downloading latest numpy didn't help.
Also moved some WBs elsewhere and no change. Thanks anyway!
EDIT:There are 2 different MOD folders: one in the official install somewhere where the official WBs are and then the one where extra WBs I get when using the download manager go - appdata something. Deleted cadquery_module and Curves WBs and all good now. I don't know what I'm doing so . Thanks!
During initialization the error
Importing the multiarray numpy extension module failed. Most
likely you are trying to import a failed build of numpy.
If you're working with a numpy git repo, try `git clean -xdf` (removes all
files not under version control). Otherwise reinstall numpy.
Original error was: cannot import name multiarray
occurred in freecad.asm3
stuff
An old bugged release of cadquery was installing a wrong release of bumpy. Now it is fixed.
https://github.com/jmwright/cadquery-fr ... issues/120
- dcapeletti
Hi, A2Plus already supports parts list BOM https://forum.freecadweb.org/viewtopic. ... 80#p266007
I would like to know if assembly 3 will support it.
Greetings
Greetings
Yes, sure. This is certainly a must have feature. It's just that there is so many features pending at the moment. This may have to wait for a few versions.dcapeletti wrote: ↑Sun Nov 04, 2018 10:33 pm Hi, A2Plus already supports parts list BOM https://forum.freecadweb.org/viewtopic. ... 80#p266007
Greetings
Excellent WB.
I noted the following detail:
When using Assembly3 WB from file f, and links to several objects in different files are made, then
if "Import all links" is made and file f is closed and then it is reopened, all links but the first one get broken .
Regards.
Regards.
I have uploaded many FreeCAD video tutorials to my YouTube channel
Thanks for reporting. I'll check that out.
When i use move tool to move an item inside the assembly, the entire assembly object will move on recompute, is there any way to "lock" the assembly object?
I am not sure I get what you want. Can you please show a screencast If a Part is locked (with 'Lock' constraint), the entire assembly will move with it, but then you asked for 'lock'?
Can make screencast later today.
Case:
Asm
Body1
Body2
Body3
Bodies are constrained in a chain. With no fixed angles.
Body1 is locked in position.
When resolving after rotating body3, the assembly is rotated rather then the joint between body2 and body3.
In best case both the assembly placement and the joint between b2 and b3 is updated ^_^
What i expect:
Assembly placement stays fixed when arranging/solving body inside the assembly.
Hmm. Normally i use "joint" and "link", but in this thread using link for geometry between joints may be confusing so i use body instead.
