Assembly3 preview
realthunder
Re: Assembly3 preview
Postby realthunder » Fri Nov 09, 2018 9:03 am
fosselius wrote:
Fri Nov 09, 2018 8:54 am
Can make screencast later today.
Please also attach a sample file if possible
Are these body inside a subassembly? The default behavior of asm3 mover is to move part in the context of the top level assembly. If the body3 is inside a subassembly, you can select the body3 as usual, and then ctrl select its parent assembly (body2?), then click mover button. This tells the mover to move in context of a specific sub assembly.
Try Assembly3 (latest version 0.10) along with my custom build of FreeCAD at here.
fosselius
Postby fosselius » Fri Nov 09, 2018 9:15 am
This is a simple asm with a few parts, no sub asm, or Parts, or nesting. Pretty much the basic usecase. A few geometries and constraints. started seeing this a release or two ago, mentioned it then as well: https://forum.freecadweb.org/viewtopic. ... &start=820
Will also try your prebuilt release as well to make sure its nothing local on my machine.
fosselius
Postby fosselius » Fri Nov 09, 2018 10:01 am
I think the move tools is the core issue for me..
realthunder
Postby realthunder » Fri Nov 09, 2018 10:30 pm
Can you attach a file showing the problem? I can't reproduce it with the last released AppImage.
fosselius
Postby fosselius » Sat Nov 10, 2018 10:01 am
My bad. Was based on my outdated linkstage3 fork. Have now synced my fork and are rebuilding..
It works fine for me as well with the latest app image.
OakLD
Postby OakLD » Sat Nov 10, 2018 9:11 pm
I experience some dejavu effects in assemblies tested in ASM3. I'd attach the ZIP file of this shed structure, but it's too large for this forum (circa 2,5MB).
Some set's of parts in one of the sub-assembly (shown above) are shown twice for no obvious reason. They are not entered twice, they have no representation in the tree. Also, I have no idea why whole sets of parts (3, 3 and 4).
When inherited in parent assembly, they dissapear and it looks correctly:
However, when I wanted to place it into drawing area, I had to do PartWB: Part --> Create Copy --> Create Simple Copy and new display problems with the very same parts appear, which even persist into drawing area:
Notice, that this time the original parts are missing, only parts in wrong position are shown.
Any ideas how to troubleshoot it and fix the issues?
Regards,
Oak
ceremcem
Postby ceremcem » Sat Nov 10, 2018 9:24 pm
One trick I'm using is:
  1. Go to Github and open an issue (in any repository)
  2. Drag and drop your attachment into the issue text area, let Github upload the attachment
  3. Share that link
  4. You can dispose that issue on Github
OakLD
Postby OakLD » Sat Nov 10, 2018 9:37 pm
  3. Share that link
Thank you for your advice. I set up an account, created an issue in Realthunders Assembly3 project and hopefully, here is a valid link:
https://github.com/realthunder/FreeCAD_ ... ahrDom.zip
Regards,
Oak
realthunder
Postby realthunder » Sun Nov 11, 2018 10:58 pm
Thanks for reporting. There are two problems. The Part simple copy bug has already been fixed in my branch. The second visibility problem is harder to deal with. Notice that in your attached file, you have already hide the Assembly object, but it is still showing in 3D view. Those shown in 3d view are not from the Assembly, but the part links themselves. The problem occurs when other non-asm3 code operate on parts inside an assembly, and changes its visibility property. This is really confusing to the end user, and hard to explain. I must find a solution for this.
ceremcem
Postby ceremcem » Sun Nov 11, 2018 11:46 pm
The visibility problem may be very hard to realize but it's very easy to work around once you suspected: See "Quick workaround": https://github.com/realthunder/FreeCAD_ ... -356300913
Could we somehow help on this? One way is to serve as a rubberduck (as http://rubberduckdebugging.com suggests) at least. IMO, the solution will shine once you (could?) explained the problem to me (us). (In other words, I won't do anything other than listening :) )
