Assembly3 preview
vocx
Re: Assembly3 preview
Postby vocx » Fri Jan 17, 2020 2:14 am
realthunder wrote:
Thu Jan 16, 2020 9:47 pm
...Yes, it should be installable by now. And solvespace solver (py_slvs) is also installable through PyPi. Not sure if it is possible to auto install required PyPi package through the manager.
Please add this information to your top level README.md file in the Assembly3 repository.
The Addon Manager will not install dependencies for you, but you can guide the user on the requisites to run your workbench. The Addon Manager will display that README.md, so provide helpful information, including where to get help and links to tutorials.
Something like this
Assembly3 requires FreeCAD version 0.19 to work. It does not work with 0.18 or below.
You need to install the Solvespace solver as well. Using pip, `pip3 --user install py_slvs`
See the page for Assembly4 for inspiration. https://github.com/Zolko-123/FreeCAD_Assembly4
Kunda will add your Assembly3 repository as a submodule of the FreeCAD-addons repository, and then it will become available immediately.
realthunder
Postby realthunder » Fri Jan 17, 2020 4:43 am
Thanks for the tip. Will do that soon.
looo
Postby looo » Fri Jan 17, 2020 7:23 am
For appimage and dmg the solvespace package is already included. Better to not use pip for these builds as compatibility is not guaranteed.
Postby Kunda1 » Fri Jan 17, 2020 7:36 am
Thanks @vocx I misunderstood. ;)
@realthunder, ping me when you're ready and I'll add Assembly3 to the Addon Manager ;)
realthunder
Postby realthunder » Fri Jan 17, 2020 8:26 am
Yes, I'll mention that in Readme.
BassMati
Postby BassMati » Wed Jan 22, 2020 10:21 pm
Referencing a Property of a Linked External Object
I am working on a Assembly 3 tutorial about working with component alternatives. The idea is that dimensions change automatically when a (ball bearing) component is exchanged for another.
There are two ball bearing component files (ball-bearing-a and ball-bearing-b) with slightly different dimensions but identical structures and names, and a project-file. The project-file has 3 objects, two links to the external ball bearing components, and the bearing plate body (see fig-001 in the attachments). The holes sizes in the plate are linked to the bearing component sketches via sub-object shape binders. When I switch the LinkedObject properties from the external ball-bearing-a to ball-bearing-b or vice versa, the hole diameters in the plate change as expected to accommodate the different diameters. This works fine.
Now I want the plate thickness be determined by the Ball Bearing 2 width (Pad.Length), and the plate thickness should change according to the linked external component. For this purpose, I tried to set a formula into Bearing Plate > Pad.Length, something like Link001.Pad.Length, but the expression engine doesn't accept this.
The problem seems to be a sort of ambiguity in the object names in the model tree - there are 3 objects with the internal name "Pad", so I cannot simply distinguish them in the formula.
I can reference the ball bearing pad in the external file with "ball-bearing-b#Pad.Length", but that whould defeat the purpose (because when a different bearing is used, the formula has to be edited, too.
So the question is: Is it possible?
Thanks in advance
Ulrich
OS: Windows 10 (10.0)
Version: 0.19.17089 +1543 (Git)
Branch: LinkStage3
Hash: 950c082111ae5ebeefb4dddc90a80dc9b54b2408
Python version: 3.6.8
Qt version: 5.12.1
project-file.FCStd
(17.81 KiB) Downloaded 15 times
ball-bearing-b.FCStd
(30.17 KiB) Downloaded 10 times
ball-bearing-a.FCStd
(31.58 KiB) Downloaded 9 times
BassMati
Postby BassMati » Thu Jan 23, 2020 10:04 am
Referencing a Property of a Linked External Object - Solution
I found the Solution with the help of the Python Console and some hours of sleep.
The formula is
Link001.LinkedObject.Document.Pad.Length
Link001 is the internal name of the "Ball Bearing 2" object, which points to the "ball-bearing-a" or "ball-bearing-b" file object, according to the value of its "LinkedObject" property. Its "Document" property returns an object which carries the ball bearing model objects. These can be accessed with their internal names, line "Pad" in the example.
Sorry for my impatience.
Ulrich
frabice
Postby frabice » Sat Jan 25, 2020 3:06 pm
Hello everyone,
I am giving a try to assembly3 to redesign my 3D printer. I am starting with some king of dummy axis for practice. I would be interested if my use of the workbench is OK or if there are tricks that could have been nice to use for the small assembly attached.
I have also some questions:
  1. Is there a button to add a part to the assembly? Drag and drop is not very well supported on my machine
  2. Is there a feature to know what are the redudant constraints that make the message pop up in the report view?
  3. Is there a trick to make part move tool more fluid or is it just my old machine that is not fast enough anymore (2009 macbook pro)?
Thank you for your help and your work on freecad!
OS: macOS 10.14
Version: 0.19.16830 +1504 (Git)
Branch: LinkStage3
Hash: c80967b68820e135b93c6e69a5a538adf58da504
Python version: 3.7.3
Qt version: 5.9.7
Locale: French/France (fr_FR)
assembly_axe_y.zip
(216.67 KiB) Downloaded 10 times
realthunder
Postby realthunder » Sat Jan 25, 2020 11:41 pm
The formula is
This is not the best way to reference an external sub-object. There are a lot of housekeeping done by the expression engine behind the scene to auto change the reference name when you do things like copy or rename and stuff. But it only works if you reference the object using expression's identifier syntax. The way you are doing right now is reference through Python attributes. Here is the proper way,
Link001.<<Pad.>>.Length
This is reference by object's internal name. If you are swapping files, you must make sure the other file also have an object with the same internal name 'Pad'. And this is not always possible, because internal names are not user changeable. In this case, you can use label reference. Just remember to not include any '.' in your object label. Once you have this expression somewhere in any open document, and you rename your Pad to some other name, the expression will be auto updated to follow you changes.
Link001.<<$MyPadName.>>.Length
realthunder
Postby realthunder » Sat Jan 25, 2020 11:55 pm
[*]Is there a button to add a part to the assembly? Drag and drop is not very well supported on my machine
It is not possible right now, but I can add that function. However, if drag and drop don't work then how do you add your existing parts?
[*]Is there a feature to know what are the redudant constraints that make the message pop up in the report view?
Turn on the 'Verbose' property of the assembly object. And make sure you click the 'Solve' button instead of using auto solve (auto done when you change assembly), or quick solve (another button, which is essentially what auto solving does). Reporting redundant constraint requires a full solve, and it may take much longer time.
[*]Is there a trick to make part move tool more fluid or is it just my old machine that is not fast enough anymore (2009 macbook pro)?
Turn off 'auto solve' (with the toolbar button), or hole 'CTRL' key (META key for mac?) while moving, which bypass auto solving. You may also find 'Axial mover' easier to use than the standard mover. You can also try 'quick mover' which does not trigger auto solving.
