I see. That's why it works at the Mod in build directory, but not at home.looo wrote: ↑Tue Dec 05, 2017 4:33 pm https://github.com/realthunder/FreeCAD/ ... it.py#L124
That was part of a previous attempt to solve name-clashes.
Assembly3 preview
Re: Assembly3 preview
Unfortunately, no. You'll need to build my branch at https://github.com/realthunder/FreeCAD/tree/LinkStage3freecad-heini-1 wrote: ↑Tue Dec 05, 2017 9:30 am Thank you so much for your work. Is it useable with Freecad 0.17?
Will try on Windows soon. This the reason why I haven't submit any PR to SolveSpace folks yet. Gotta try on Windows first.
sorry, I was wrong. I thought ModDIR refers to .FreeCAD/Mod but it does not. The line isn't different in FreeCAD/master. No idea whats causing your local build to work with importing directly from .FreeCAD/Mod.I see. That's why it works at the Mod in build directory, but not at home.
I was saying that it doesn't work in .FreeCAD/Mod for me either. But it works when putting asm3 into the Mod directory of the build/installation directory, apparently because of the sys.path inclusion you pointed out.looo wrote: ↑Tue Dec 05, 2017 7:35 pmsorry, I was wrong. I thought ModDIR refers to .FreeCAD/Mod but it does not. The line isn't different in FreeCAD/master. No idea whats causing your local build to work with importing directly from .FreeCAD/Mod.I see. That's why it works at the Mod in build directory, but not at home.
Now I understand. So we have inconsistence between the "root"-Mod directory and the "user"-Mod directory.
Yes.saso wrote: ↑Tue Dec 05, 2017 2:59 pm You have compiled his https://github.com/realthunder/FreeCAD/tree/LinkStage3 ? It only works with it
About the possibility to run from Mod in the build directory. Unfortunately that doesn't work for me (i get the same behavior as when .FreeCAD/Mod is used). But all in all great we can now both reproduce this.realthunder wrote: ↑Tue Dec 05, 2017 7:12 pm You are doing exactly the same as I am doing, i.e. running directly from a build directory, with maybe one exception. I put the asm3 module directly in Mod directory of the build directly (well, actually through a symlink), instead of ~/.FreeCAD/Mod. I vaguely remember having some issue putting the module there early development.
Yup, just tried it. It doesn't work in ~/.FreeCAD/Mod. Try Mod in the build directory, it shall work fine there. I'll migrate to the new style for sure, but may take a while, because things at work.
P.S. As for changing imports take your time.
But don't read this as i am not eager to try it ASAP.
Ickby is working on assembly workbench for Freecad 0.17. What about teamwork?realthunder wrote: ↑Tue Dec 05, 2017 7:19 pmUnfortunately, no. You'll need to build my branch at https://github.com/realthunder/FreeCAD/tree/LinkStage3freecad-heini-1 wrote: ↑Tue Dec 05, 2017 9:30 am Thank you so much for your work. Is it useable with Freecad 0.17?
I've discussed with him in quite a few occasions. For example, see here, and here. As you can see, we have different opinions on how the container should behave. And unfortunately, none of the discussions lead anywhere.freecad-heini-1 wrote: ↑Wed Dec 06, 2017 8:05 am Ickby is working on assembly workbench for Freecad 0.17. What about teamwork?
