Assembly3 preview
bambuko
Re: Assembly3 preview
Post by bambuko »
Kuzma30 wrote: Thu Mar 24, 2022 1:10 pm Fine, but not correct... I updated a few files on github....
I know, these are original files - my interest was in why I could open them OK and jpg87 couldn't?
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
adrianinsaval
Post by adrianinsaval »
bambuko wrote: Thu Mar 24, 2022 1:37 pm yes, I thought about it as well, but if it was the case I would have similar problem :?:
don't be too sure, it could be that there's some error in the full path too.
ToniTen
Post by ToniTen »
I ask here instead of straight starting a feature request on GitHub because I don't want to create extra noise on the github is I can avoid it, but for interoperability with people that don't have Assembly3 installed, is there any kind of "Assembly3 Downgrade"/"Assembly3 Explode" tool to turn an Assembly3 Assembly in just a regular FreeCAD collection of Parts, Bodies and shapes? Ideally it should work recursively, to go into sub-assemblies and downgrade/explode those too.
I obviously don't expect them to remain constrained by the constraints, just left in place. Assemblies (freecad.asm3.assembly.Assembly objects) could be replaced with App::PART containers, to keep the hierarchy and Placement properties intact.
adrianinsaval
There's probably a way of doing that with a macro
jpg87
Post by jpg87 »
bambuko wrote: Thu Mar 24, 2022 1:39 pm my interest was in why I could open them OK and jpg87 couldn't?
Kuzma30 wrote: Thu Mar 24, 2022 1:10 pm...
After unsuccessful efforts, I deleted the "...Roaming/FreeCAD" folder and restarted FreeCAD
OS : Windows 10 Version 2009
Word size of FreeCAD : 64-bit
Version : 2022.118.30769 (Git)
Build type : Release
Branch : LinkDaily
Hash : 3b620b713e24c9637db8ea6ad1f1ee88ef13367a
Python version : 3.8.6+
Qt version : 5.15 .2
Version Coin : 4.0.1
Version OCC : 7.6.0
Locale : Français/France (fr_FR)
Now I have this message on startup (??)
18:30:54 'charmap' codec can't encode characters in position 324-336: character maps to <undefined>
I finally manage to open the assembly file, but unlike @bambuko , I don't have Elements or Constraints :
The settings file was grayed out in the list, and after activating it I saw the different settings pages appear :
After changing the number of bars to 7 and recalculating the assembly file, the 7 bars appear fine :
Looking at the contents of other files, I discovered this problem. After opening and closing the distressed sketch, it self-corrected, so I wanted to do the same for the pad. No internal error, but after validation, here is the message :
So I still don't have a complete set ...
Did you already install constraints that I should have found when opening the assembly, or were you stuck with the multiplication of profiled bars?
My website : http://help-freecad-jpg87.fr updated 2023/11/06
Zolko
Post by Zolko »
Kuzma30 wrote: Wed Mar 23, 2022 10:43 am Ukraine will win.
I very much doubt this
Kuzma30
Post by Kuzma30 »
jpg87 wrote: Thu Mar 24, 2022 6:14 pm So I still don't have a complete set ...
Please update files from github, I make some changes. In "MainAssembly" file there is 2 sub-assembly - PlateForFK12 and PlateForMotor. Both of it produce error such
08:52:56  <App> solver.py(376)|PropertyLinks.cpp(399): NEMA23#Sketch007.Support auto change element reference NEMA23#Boolean ;#1481;:M#1e1e;FUS;:T3189:5:F.Face19 -> ;#2ec3;:M#2ec2;FUS;:Hc75:c,F.Face19
08:52:56  <App> solver.py(376)|PropertyLinks.cpp(399): NEMA23#Sketch.Support auto change element reference NEMA23#Pocket ;#1f53;:M;CUT;:T3187:5:F.Face9 -> ;#30e1;:M;CUT;:Hc73:7,F.Face9
08:52:56  <App> solver.py(376)|PropertyLinks.cpp(399): NEMA23#_Element001.LinkedObject auto change element reference NEMA23#Pocket Pocket.;#1f53;:M;CUT;:T3187:5:F.Face9 -> Pocket.;#30e1;:M;CUT;:Hc73:7,F.Face9
08:52:57  32.845285 <asm3.sys> sys_slvs.py(71): dof remaining: 2
08:52:57  0.149593 <asm3.sys> system.py(244): auto relax constraint (MainAssembly#AxialAlignment004) MainAssembly#Constraint008 between (MainAssembly#PlateY2) MainAssembly#Link002 and (MainAssembly#NEMA23) MainAssembly#Link003, 2
08:52:57  0.000988 <asm3.sys> system.py(244): skip redundant constraint (MainAssembly#AxialAlignment005) MainAssembly#Constraint009 between (MainAssembly#NEMA23) MainAssembly#Link003 and (MainAssembly#PlateY2) MainAssembly#Link002, 3
08:52:57  0.013979 <asm3.sys> solver.py(133): List of failed constraint:
(MainAssembly#AxialAlignment003) MainAssembly#Constraint006, handle: 1
(MainAssembly#AxialAlignment003) MainAssembly#Constraint006, handle: 2
(MainAssembly#PlaneAlignment001) MainAssembly#Constraint005, handle: 3
(MainAssembly#PlaneAlignment001) MainAssembly#Constraint005, handle: 4
(MainAssembly#AxialAlignment004) MainAssembly#Constraint008, handle: 5
(MainAssembly#AxialAlignment006) MainAssembly#Constraint010, handle: 6
(MainAssembly#AxialAlignment006) MainAssembly#Constraint010, handle: 7
(MainAssembly#AxialAlignment007) MainAssembly#Constraint011, handle: 8
(MainAssembly#AxialAlignment007) MainAssembly#Constraint011, handle: 9
(MainAssembly#AxialAlignment008) MainAssembly#Constraint012, handle: 10
(MainAssembly#AxialAlignment008) MainAssembly#Constraint012, handle: 11
(MainAssembly#AxialAlignment009) MainAssembly#Constraint013, handle: 12
(MainAssembly#AxialAlignment009) MainAssembly#Constraint013, handle: 13
(MainAssembly#PlaneAlignment002) MainAssembly#Constraint014, handle: 14
(MainAssembly#PlaneAlignment002) MainAssembly#Constraint014, handle: 15
(MainAssembly#PlaneAlignment003) MainAssembly#Constraint015, handle: 16
(MainAssembly#PlaneAlignment003) MainAssembly#Constraint015, handle: 17
(MainAssembly#PlaneAlignment004) MainAssembly#Constraint016, handle: 18
(MainAssembly#PlaneAlignment004) MainAssembly#Constraint016, handle: 19
08:52:57  33.014848 <asm3.gui> gui.py(459): command "asm3CmdSolve" exception
  File "C:\Users\kuzem\AppData\Roaming\FreeCAD\Mod\FreeCAD_assembly3\freecad\asm3\solver.py", line 110, in __init__
    self.system.solve(group=self.group,reportFailed=reportFailed)
  File "C:\Users\kuzem\AppData\Roaming\FreeCAD\Mod\FreeCAD_assembly3\freecad\asm3\sys_slvs.py", line 70, in solve
    raise RuntimeError(reason)
RuntimeError: inconsistent constraints
During handling of the above exception, another exception occurred:
  File "<string>", line 627, in report
  File "C:\Users\kuzem\AppData\Roaming\FreeCAD\Mod\FreeCAD_assembly3\freecad\asm3\solver.py", line 412, in solve
    return _solve(*args,**kargs)
  File "C:\Users\kuzem\AppData\Roaming\FreeCAD\Mod\FreeCAD_assembly3\freecad\asm3\solver.py", line 382, in _solve
    Solver(assembly,reportFailed,dragPart,recompute,rollback)
  File "C:\Users\kuzem\AppData\Roaming\FreeCAD\Mod\FreeCAD_assembly3\freecad\asm3\solver.py", line 113, in __init__
    raise RuntimeError(translate('asm3', 'Failed to solve {}: {}').format(
RuntimeError: Failed to solve (MainAssembly#PlateForMotor) MainAssembly#Assembly002: inconsistent constraints
RealThunder's A3 Wiki translation, join the project https://crowdin.com/project/freecad-asm3-wiki
jpg87
Post by jpg87 »
Kuzma30 wrote: Fri Mar 25, 2022 6:54 am ... In "MainAssembly" file there is 2 sub-assembly - PlateForFK12 and PlateForMotor.
Obviously, you did it like this: as in the real world, you aligned solid cylinder and hollow cylinder (AxialAlignment), then brought plane to plane into contact (PlaneAlignment).
In virtual assembly, one must anticipate the expected result:
  • either you want to create a guidance in rotation (1 DOF kept in rotation around the common axis) and in this case you can directly use the PlaneCoincident constraint (whose name does not explicitly translate its capacities if we do not know them) by cleverly choosing the Elements to use,
  • either you want to position the two components without keeping any DOF: in this case, use the Attachment constraint instead and adapt the position of one of the Elements if necessary (NB: it may be necessary to use the function "Flip element" or "Flip part").
Big advantage of this last constraint: it does not use solver resources.
If you want me to send you my files, I will put them online in the evening.
Kuzma30
Post by Kuzma30 »
jpg87 wrote: Fri Mar 25, 2022 12:50 pm If you want me to send you my files, I will put them online in the evening.
It would be great.
jpg87
Post by jpg87 »
Kuzma30 wrote: Fri Mar 25, 2022 4:15 pm...
I had time to integrate the bars in the "СтанинаСборка.FCStd" assembly.
After changing the number of bars in the "ТаблицаПараметров.FCStd" file (ТаблСтанина table), you must update the assembly (F5), then recalculate in Assembly 3 to update the constraints.
03Number bars.png (29.82 KiB) Viewed 4014 times
05Solve constraints.png (150.76 KiB) Viewed 4014 times
Files : https://www.dropbox.com/s/ccbrxymbfywnr48/06cnc.7z?dl=0
