Assembly3 preview
looo
Re: Assembly3 preview
Post by looo »
@realthunder
should we exclude asm3 from the 0.19.1 release? For now I simply used the 0.19.pre bundles as base and there we have installed some additional addons.
Post by Kunda1 »
looo wrote: Sun Mar 28, 2021 12:55 pm @realthunder
Isn't the solvespace solver bundled in to asm3 ? If so then there may be a licensing issue since it's GPL2 as it's pre-bundled in FC AppImages. We may need to make asm3 an addon in that case (or make the solvespace solver an addon) ?
edavis
Post by edavis »
This is minor but in the spreadsheet you have to type 'inch'. 'in' does not work but will display if that is what is set to display. 'mm' is ok.
In 19.1 and back 'in' was OK. 'inch is not'
Thanks, Ed
OS: Windows 10 (10.0)
Version: 2021.328.24301 +3441 (Git)
Branch: LinkStage3
Hash: 0a157a307c91d241a370cdda6d8f0471b7c48915
Python version: 3.6.8
Qt version: 5.12.6
OCC version: 7.5.0
test spreadsheet.FCStd
(9.66 KiB) Downloaded 90 times
realthunder
Post by realthunder »
Kunda1 wrote: Sun Mar 28, 2021 4:21 pm Isn't the solvespace solver bundled in to asm3 ? If so then there may be a licensing issue since it's GPL2 as it's pre-bundled in FC AppImages. We may need to make asm3 an addon in that case (or make the solvespace solver an addon) ?
Is it possible to install pip package from within FreeCAD now? The SolveSpace solver can be installed through pip.
Try Assembly3 with my custom build of FreeCAD at here.
realthunder
edavis wrote: Tue Mar 30, 2021 12:32 am This is minor but in the spreadsheet you have to type 'inch'. 'in' does not work but will display if that is what is set to display. 'mm' is ok.
'in' is a reserved keyword in the extended Expression Syntax in my branch. For compatibility with the upstream 0.19, you can use " instead. I'll find a better way for migration later.
edavis
Post by edavis »
OK RT. And thank you for the work your doing.
Ed
steve123
Post by steve123 »
@looo
Heads up, the "0.19.pre" tag has disappeared from the repo and the link from the downloads page is broken.
Modeler
file compatibility
Post by Modeler »
Do you want reports of file current incompatibility between FreeCAD 19.1 and RealThunder Link Branch? I assume you will want these at some point but do you want them now?
Re: file compatibility
Modeler wrote: Sat May 01, 2021 6:09 pm Do you want reports of file current incompatibility between FreeCAD 19.1 and RealThunder Link Branch?
Moved to Assembly3 topic.
skopjanecot
Post by skopjanecot »
My FreeCAD LinkBranch crashes when I try to open the Mesh Design WB.
OS: macOS 11.3
Version: 2021.504.24301 +3511 (Git)
Branch: LinkStage3
Hash: b8cd87c34a66a8f7a8177f483cebf79e29273813
Python version: 3.9.4
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
