Assembly3 preview
Zolko
Re: Assembly3 preview
Postby Zolko » Fri Jan 25, 2019 2:53 pm
Hello realthunder, I've found a bug in your latest release:
I had made earlier some experimenting with the Path workbench, to produce Gcode for manufacturing some real parts. This was done with:
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15363 (Git) AppImage
Hash: 9be3e633328335f1172456f5857219b7a08c70a5
Python version: 3.6.7
Qt version: 5.6.2
I didn't yet use the Gcode (with an Arduino Shield). But when I load the 2 files in your latest AppImage, it crashes hard
FreeCAD 0.18, Libs: 0.18R16235 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Part__Feature
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Cylinder
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Fusion
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Clone
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Stock001
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#MillFace
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Profile_Edges
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Profile_Edges001
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Clone001
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Pocket_Shape
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Profile_Edges002
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Pocket_Shape001
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Profile_Edges003
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Pocket_Shape002
<PropShape> PropertyTopoShape.cpp(338): auto generate element map: support_SiWafer#Pocket_Shape003
PathJob.INFO: Converting Job.Base to new Job.Model for detourage
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f4ef0719f20]
#1  /usr/lib/x86_64-linux-gnu/libstdc++.so.6(__dynamic_cast+0x20) [0x7f4ef0d75360]
#2  0x7f4ef2c9ed87 in App::Document::afterRestore(std::vector<App::DocumentObject*, std::allocator<App::DocumentObject*> > const&, bool, bool) from ././/lib/freecad-daily/lib/libFreeCADApp.so+0x567
#3  0x7f4ef2cae48d in App::Document::afterRestore(bool, bool) from ././/lib/freecad-daily/lib/libFreeCADApp.so+0x3d
Version: 0.18.16235 (Git) AppImage
Build type: None
Branch: (HEAD detached at FETCH_HEAD)
Hash: 49e18e2cb348edc6c565d8a10e59363de23f5880
Python version: 2.7.6
Qt version: 4.8.6
files attached
support_SiWafer.fcstd
(123.34 KiB) Downloaded 14 times
support_LensArray.fcstd
(128.17 KiB) Downloaded 17 times
bill
Postby bill » Fri Jan 25, 2019 8:17 pm
Yes, in ubuntu 16.04, it loads, renders, then app goes away!
Zolko
Postby Zolko » Fri Jan 25, 2019 9:22 pm
Can you please copy your FreeCAD version information ? (Help -> About FreeCAD -> copy to clipboard) .
realthunder
Postby realthunder » Fri Jan 25, 2019 11:34 pm
Thanks for reporting. It's been fixed. Please sync LinkStage3 and try again. I'll release a new image soon.
Zolko
Postby Zolko » Mon Jan 28, 2019 8:54 am
realthunder wrote:
Fri Jan 11, 2019 10:59 pm
OakLD wrote:
Fri Jan 11, 2019 4:19 pm
One of those elementary question still remain unanswered - why the files are opened in the first place? I.e. you don't show a configuration text file to user, when you're reading configuration lines from it.
So, you are essentially complain about a UI problem? Too many tabs, is that it?
I didn't step in at that time, but I think that OakLD is right, and this could cause problems in the future: when you have hundreds of parts in an assembly, having hundreds of windows (tabs) opened will make it unusable. And when I close a window on a part that is included in an assembly, the part disappears from that assembly.
So while I understand that a part must be "open" for it to be included in an assembly, does it need a GUI window for that ? There is a command-line version of FreeCAD, how does it open a document if it has no GUI at all ?
realthunder
Postby realthunder » Mon Jan 28, 2019 10:58 am
I was not discarding his complain when I reply that. In fact, I was acknowledging this as a GUI problem, which I'll find a way to improve it in the future.
Zolko
Postby Zolko » Mon Jan 28, 2019 12:27 pm
[ 17%] Building CXX object src/Gui/CMakeFiles/FreeCADGui.dir/WidgetFactory.cpp.o
In file included from /usr/include/x86_64-linux-gnu/qt5/QtCore/qiodevice.h:43:0,
                 from /usr/include/x86_64-linux-gnu/qt5/QtCore/qtextstream.h:43,
                 from /usr/include/x86_64-linux-gnu/qt5/QtCore/QTextStream:1,
                 from /home/hubertz/Documents/3Dcad/FreeCAD/FreeCAD-LinkStage3_git/FreeCAD/src/Gui/WidgetFactory.cpp:28:
/home/hubertz/Documents/3Dcad/FreeCAD/FreeCAD-LinkStage3_git/FreeCAD/src/Gui/WidgetFactory.cpp: In member function ‘QIcon* Gui::PythonWrapper::toQIcon(PyObject*)’:
/home/hubertz/Documents/3Dcad/FreeCAD/FreeCAD-LinkStage3_git/FreeCAD/src/Gui/WidgetFactory.cpp:367:14: error: ‘icon’ was not declared in this scope
     Q_UNUSED(icon);
/home/hubertz/Documents/3Dcad/FreeCAD/FreeCAD-LinkStage3_git/FreeCAD/src/Gui/WidgetFactory.cpp:367:14: note: suggested alternative: ‘QIcon’
src/Gui/CMakeFiles/FreeCADGui.dir/build.make:7844: recipe for target 'src/Gui/CMakeFiles/FreeCADGui.dir/WidgetFactory.cpp.o' failed
make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/WidgetFactory.cpp.o] Error 1
CMakeFiles/Makefile2:6119: recipe for target 'src/Gui/CMakeFiles/FreeCADGui.dir/all' failed
make[1]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
I had this before, so I commented out that line #367 in ~/src/Gui/WidgetFactory.cpp: //Q_UNUSED(icon); and it passes ...
Zolko
Postby Zolko » Mon Jan 28, 2019 1:44 pm
it compiles and runs now, but I have a problem with my PySide2 install, therefore many things don't work. I use your latest asm3 AppImage as standard now.
Brutha
Postby Brutha » Wed Jan 30, 2019 9:48 am
Hi All,
Testing (and trying to find my way round A3!) on OSX. I wanted to use a angle constraint to pivot the two plates around a hinge (indicated by the red line). See attached file.
The axial constraint works fine to link the two plates. The angle constraint gives an issue though, I just get the message "Failed to solve unnamed assembly: inconsistent constraints".
Did I miss some important part of the process?
Thanks!
Brutha
OS: macOS 10.14
Version: 0.18.14555 (Git shallow)
Python version: 2.7.15
Qt version: 5.11.2
a3_angle.FCStd
(31.48 KiB) Downloaded 11 times
Brutha
Postby Brutha » Wed Jan 30, 2019 12:34 pm
Update: actually I found that wrapping each part in an assembly, then combining those into another assembly seemed to work nicely!
