Please add this information to your top level README.md file in the Assembly3 repository.realthunder wrote: ↑Thu Jan 16, 2020 9:47 pm...Yes, it should be installable by now. And solvespace solver (py_slvs) is also installable through PyPi. Not sure if it is possible to auto install required PyPi package through the manager.
The Addon Manager will not install dependencies for you, but you can guide the user on the requisites to run your workbench. The Addon Manager will display that README.md, so provide helpful information, including where to get help and links to tutorials.
Something like this
Assembly3 requires FreeCAD version 0.19 to work. It does not work with 0.18 or below.
You need to install the Solvespace solver as well. Using pip, `pip3 --user install py_slvs`
Kunda will add your Assembly3 repository as a submodule of the FreeCAD-addons repository, and then it will become available immediately.
