Assembly3 preview
arcol
Garage door and assembly3
Postby arcol » Sun Sep 20, 2020 7:39 pm
I would like to model a garage door with assembly 3 workbench. I modelled the frame, the two door panels, and also the hinges.
But I can not figure out how to put the hinge on the door panel with the assembly3 workbench.
My end goal is to be able to rotate the doorpanel around the hinge, and make small adjustment before I weld it on in real life.
Here are some pictures, and I also attached the freecad model itself.
GarageDoor
GarageDoor.FCStd
(698.07 KiB) Downloaded 15 times
Reason: Merged in to Assembly3 thread
ToniTen
Re: Assembly3 preview
Postby ToniTen » Fri Sep 25, 2020 3:20 pm
I've been using the Freecad-Daily PPA for a while, to enjoy the goodness of the latest developments, and automatic updates on ubuntu, and I wanted to know if it's possible to bolt assembly3 to it. Since it's based on the master git, it should include solvespace and other required libraries right? Appimages are bloated.
In an ideal world, I would like to git clone the repo somewhere, symlink asm3 to .FreeCAD/MOD/ and call it a day with regular git pulls to keep it updated. However, that doesn't seem to work. Maybe I'm missing something obvious though.
Luixx
Postby Luixx » Fri Sep 25, 2020 4:02 pm
hello, i'am italian .. use version:
OS: Windows 10 (10.0)
Version: 0.19.22492 (Git)
Hash: 621e1d603b2a8d1bcdcd8dc5c34bc8c35d29feb2
Python version: 3.8.5
Qt version: 5.12.6
OCC version: 7.4.0
Locale: Italian/Italy (it_IT)
Click mouse right .. error for screenshot:
1: open from model
2: open workbench "Assembly 3"
3: Click view port
4: error view
18:02:37  36.73037 <asm3.main> init_gui.py(75):
  File "<string>", line 519, in _catch
  File "D:\Apps\FreeCAD_0.19.22492-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\freecad\asm3\init_gui.py", line 63, in _contextMenu
    name = cmd.getContextMenuName()
  File "D:\Apps\FreeCAD_0.19.22492-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\freecad\asm3\gui.py", line 229, in getContextMenuName
    if cls.IsActive() and cls._contextMenuName:
  File "D:\Apps\FreeCAD_0.19.22492-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\freecad\asm3\gui.py", line 964, in IsActive
    return FreeCADGui.isCommandActive('Std_LinkSelectLinked')
AttributeError: module 'FreeCADGui' has no attribute 'isCommandActive'
sgrogan
Postby sgrogan » Fri Sep 25, 2020 4:05 pm
Solvespace has incompatible license to include from the PPA. In addition realthunder uses a forked solvespace.
See here for instructions to make it work https://github.com/realthunder/FreeCAD_ ... nstruction
"fight the good fight"
realthunder
Re: Garage door and assembly3
Postby realthunder » Sat Sep 26, 2020 7:32 am
Normally, you would group (i.e. create a sub-assembly) all immovable parts together, and assembly them like a single part in some upper assembly. So just group one part of the hinge with the frame using either Attachment (prefered) or PlaneCoincidence constraint, group the other part with the door similarly, and then create the master assembly with these two parts using a PlaneCoincidence.
realthunder
Postby realthunder » Sat Sep 26, 2020 7:39 am
You can use the upstream AppImage which includes everything I believe. You can update AppImage as well using Preference->AppImage dialog. Or you can try my personal release of AppImage, which contains lots of extra features. I usually sync with upstream master every month or two.
realthunder
Postby realthunder » Sat Sep 26, 2020 8:26 am
1: open from model
3: Click view port
4: error view
It is caused by a recent change in master. You can try update asm3 workbench using addon manager and get the fix now.
Luixx
Postby Luixx » Sat Sep 26, 2020 1:03 pm
1: open from model
3: Click view port
4: error view
ok, how to download from addon manager??
view : assembly 4
view : assembly 2
assembly 3 ?? not found from addons manager?
Downloads??
Syres
Postby Syres » Sat Sep 26, 2020 2:35 pm
I would have thought with your Win Conda build you can just copy the attached gui.py file into src\bin\Lib\site-packages\freecad\asm3 folder.
gui.py
(33.72 KiB) Downloaded 7 times
Syres
Postby Syres » Sat Sep 26, 2020 3:38 pm
sgrogan wrote: You may not be aware
Is it worth updating the Conda builds that have Asm3 included to have the gui.py fix and therefore stop future reports or is this all done automatically?
