Assembly3 preview
jpg87
Re: Assembly3 preview
Postby jpg87 » Thu Mar 15, 2018 10:12 pm
Warning :
This expresses the results of my tests. I hope that my English translation will be understandable.
I tried to find out if the existing constraints could meet my needs.
Note :
The first reflex of the designer is to use pairs of surfaces to constrain: it would be interesting for the solver to ignore Dof deleted twice (or more).
DOF expected in the desired link (support plane):
DOF expected in the desired link (pivot):
To be continued ...
My website : http://help-freecad-jpg87.fr updated 2020/12/05
jpg87
Postby jpg87 » Thu Mar 15, 2018 10:16 pm
DOF expected in the desired link (sliding pivot) :
DOF expected in the desired link (slide) :
To be continued ...
jpg87
Postby jpg87 » Thu Mar 15, 2018 10:20 pm
DOF expected in the desired link (punctual) :
DOF expected in the desired link (straight linear) :
jpg87
Postby jpg87 » Thu Mar 15, 2018 10:24 pm
DOF expected in the desired link (spherical) :
DOF expected in the desired link (helical) :
triplus
Postby triplus » Thu Mar 15, 2018 11:31 pm
Warning :
Nice overview. Once things mature likely having such examples in the documentation would make much sense.
P.S. Before that happens i feel that this is still the missing part. That will likely change things drastically.
realthunder wrote:
Fri Mar 09, 2018 2:33 am
Because composite constraint removes multiple DOFs, multiple composite constraints of similar types on the same pair of parts (which have at most 6 Dof between them) will definitely lead to overconstraint. I'll add code to detect that and downgrade or (if appropriate) simply ignore extra composites.
Postby chrisb » Mon Mar 19, 2018 11:34 am
I hadn't much interest in assembly until now, but this overview is really intriguing.
Postby Kunda1 » Mon Mar 19, 2018 1:49 pm
marcin_ose wrote:ping
Check this thread out as well.
realthunder
Postby realthunder » Thu Mar 22, 2018 10:16 am
I am back from the topo naming thing. I've upgraded the entire Part WB with new topo naming, and It's about to be ready for testing. But before that, let's fix something here first.
It turns out that SolveSpace allows redundant constraints. I just need to ignore the return status when it reports redundant. And once I've done that, plane constraint works much better now, although it still fails occasionally. Also, multiple plane coincidence has a much lower success rate. I may still need to add my own logic to deal with this in the end of the day.
The following screencast showed a few things,
* Multiple plane alignment now works
* SolveSpace does not care about orientation, you may have to occasionally flip the object yourself. I'm not sure if there is a solution for this.
* Negative offset now works as expected
* I have added 3D view preselection on mouse over tree view item. This is a core feature, and works in other workbench as well. To turn on/off it, use tree view context menu, 'Tree view options' -> 'Pre-selection'
easyw-fc
Postby easyw-fc » Thu Mar 22, 2018 10:25 am
Very nice though!
This A3 stuff will be a great enhancement for all mechanical workflow!
:D
triplus
Postby triplus » Thu Mar 22, 2018 10:53 pm
Now plane alignment indeed works more Assembly 2 plane constraint alike. I only did a few quick tests for now. Will have more time to try out more use cases in a day or two. I can already say the amount of use cases, where before solver just failed, has reduced substantially now!
