Assembly3 preview
easyw-fc
Re: Assembly3 preview
Postby easyw-fc » Wed May 09, 2018 8:05 am
triplus wrote:
Wed May 09, 2018 7:34 am
Any chance you would be prepared to maintain a fork of Assembly 2 for the purpose of Qt5 (and potentially Py3) porting?
If we can get an A2 fork managed by FC folks, we could easy gather some user aimed to do the fix...
And then focus the efforts on A3 :D
triplus
Postby triplus » Wed May 09, 2018 8:26 am
realthunder wrote:
Wed May 09, 2018 7:43 am
I'm not sure if I'm up to the task. A2 code is not really documented, and hard to understand. I originally wanted my A3 as a fork of A2, but gave up in the middle of porting. I'm not that good at Python comparing to C++.
Fair enough.
I know there is demand as threads like this emerge:
https://forum.freecadweb.org/viewtopic.php?f=20&t=28628
There is still development activity involved:
https://forum.freecadweb.org/viewtopic. ... 59#p218959
What is therefore likely missing is somebody managing the pull requests. I tried to came up with a solution that makes some sense. As it didn't happen that is it from my side for now. Will let things evolve naturally. On macOS therefore FreeCAD 0.16 should be used to create assemblies with Assembly 2 for now.
realthunder
Postby realthunder » Wed May 09, 2018 11:20 am
Can someone please try this attached file, and try to make a draft with the following selected face. I am not familiar with PartDesignNext. I can't seem to select a neutral plane that works.
Screenshot from 2018-05-09 18-58-28.png (13.91 KiB) Viewed 812 times
The draft angle is 5 degree, and should look like this
Screenshot from 2018-05-09 19-09-30.png (13.97 KiB) Viewed 812 times
I notice that PartDesign FeatureDraft can guess a neutral plane and pull direction just fine. But the Gui TaskDraftParameters insists on an explicit neutral plane selection. What's more strange is that FeatureDraft is able to derived the neutral plane using the following Edge1? How can it be?
Screenshot from 2018-05-09 19-15-59.png (14.99 KiB) Viewed 812 times
GlouGlou wrote: ping
This is extracted from your model. How did you manage to get the draft in the first place?
pdn-draft-test.fcstd
(64.59 KiB) Downloaded 18 times
Jee-Bee
Postby Jee-Bee » Wed May 09, 2018 3:08 pm
this?
pdn-draft-test-answ.FCStd
(55.7 KiB) Downloaded 24 times
GlouGlou
Postby GlouGlou » Wed May 09, 2018 5:43 pm
The neutral plane can be like this.
The pull direction is an edge perpendicular of the plan.
Invert the direction as required. ;)
DratfGG.FCStd
(55.82 KiB) Downloaded 20 times
realthunder
Postby realthunder » Mon May 14, 2018 7:53 am
I am currently working on STEP import/export for better assembly usage. And found this interesting document (Edit: just found the latest version of the document). I was searching for some obscure abbreviation found in OCCT data exchange code, and this document perfectly explained what is missing in OCCT documentation.
Specifically, what I found interesting is this,
Screenshot from 2018-05-14 15-21-10.png (315.62 KiB) Viewed 512 times
Right now, NAUO (Next Assembly Usage Occurrence) can be directly translated to Link. But SHUO (Specific Higher Usage Occurrence) is missing, which is used to override visibility and color of an instance under a specific context. In the above picture, it means change the color of the third instance of Nut-Bot-Assembly in the second instance of L-Bracket-Assembly in the top assembly, AS1.
I think I can extend my Coin3D trick on context-aware selection, and applied it to color and visibility to achieve this.
easyw-fc
Postby easyw-fc » Mon May 14, 2018 9:27 am
I am currently working on STEP import/export for better assembly usage. And found this interesting document. I was searching for some obscure abbreviation found in OCCT data exchange code, and this document perfectly explained what is missing in OCCT documentation.
Hi @realthunder,
if you want to make some test here you can find some STEP files generated from different SW and with or without hierarchy.
https://www.cax-if.org/library/index.html
here a test file with hierarchy:
https://www.cax-if.org/library/as1-oc-214.zip
https://www.cax-if.org/library/as1-pe-203.zip
https://www.cax-if.org/library/as1-tu-203.zip
and here a file with external references (similar to what it could be done with your 'Links' pointing to external files)
https://www.cax-if.org/library/s1-c5-214.zip
https://www.cax-if.org/library/s1-pe-214.zip
https://www.cax-if.org/library/s1-tu-203.zip
Hierarchy is already well supported by FreeCAD ATM.
External references are supported only when importing the file, but are not implemented when exporting.
https://www.cax-if.org/documents/rec_pr ... ef_v21.pdf
Links could really make the difference here :D
Maurice
realthunder
Postby realthunder » Mon May 14, 2018 9:29 am
Hi @realthunder,
Thanks, much appreciated!
freedman
Postby freedman » Wed May 16, 2018 6:15 am
I just tried assembly3, it looks good but I couldn't select any faces so I really couldn't test much. What is the status of this?
OS: Windows 7
Version: 0.18.13844 (Git)
Branch: (HEAD detached at FETCH_HEAD)
Hash: 53a08259946dfa0f02bdd02a7746667902e42728
Python version: 2.7.8
OCC version: 7.0.0
realthunder
Postby realthunder » Wed May 16, 2018 6:33 am
Can you please elaborate your problem? Can you select a face when create, say a Cube, using Part, PartDesign? Does the problem happen only when the object is in the assembly? If you can show show screencast, that will be better.
