It is a multi-body part
like this is sort of ok
- Untitled.png (13.34 KiB) Viewed 697 times
this would be even better
- Untitled1.png (8.78 KiB) Viewed 697 times
but here we can again hit on about our disagreements about bodies...
however, as I said before it is possible to import such step files on different levels, above is the example of importing it on the part level (and is correct for this example since it is a multi-body part), but one could also import it on the assembly level, in this case and IF we would have the proper full implementation of the assembly, parts and bodies, then it should be like this (note the assembly container icon on top and the removed origins from the bodies
). This is also how DSM seems to import it (on the assembly level), does DSM support bodies (multi-body)?
- Untitled2.png (21.29 KiB) Viewed 677 times
