Assembly3 preview
jpg87
Re: Assembly3 preview
Postby jpg87 » Wed Jul 18, 2018 3:46 pm
OakLD wrote:
Mon Jul 16, 2018 9:03 pm
jpg87 wrote:
Mon Jul 16, 2018 7:23 am
I do not know if I answer your problem, but here is my interpretation :
Hello jpg,
yes, it is a valid answer I suppose and reasonable in some cases. Though, in the given example, the placement of the cubes by their centre point against grid or sketch is quite an important point. As explained in another post, the sketch is an information resource on it's own.
(for @realthunder too)
I wanted to test the PlaneAlignment constraint with PartDesign reference or general planes: it would be enough then that the parts would be built using these plans as planes of symmetry and that would be OK.
Test 0: Body_foot1 built into the FC file, moved to the assembly container, and then linked with Element Count = 3. PartDesign's general outline views.
When 2 or more reference planes are selected, the constraint buttons are desperately grayed out (whereas I have already tried these plans for different parts and that it worked).
Can not also select multiple circular plane faces.
Test 1: Body_foot1 built into the FC file, moved to the assembly container, and then linked with Element Count = 3. Datum planes created in coincidence with the general plans of PartDesign.
Everything is working.
Test 2: Body_foot1 built in an external FC file. 4 links of the same object created in the assembly file and moved to the assembly container. General plans of PartDesign visible.
test4feet.zip
(194.47 KiB) Downloaded 15 times
My website : http://help-freecad-jpg87.fr updated 2020/12/05
levity
Postby levity » Wed Jul 18, 2018 9:19 pm
realthunder wrote:
Thu Feb 08, 2018 11:03 pm
... Once done, to refer to an external spreadsheet, simply bring the spreadsheet into the document using an external Link, and refer to it through the local Link object.
I just tried to do this without success... I created a document: "spreadsheet_test_01.fcstd" with a spreadsheet 01 and within this spreadsheet a cell with the alias: "test" and a value: "1234"
I saved this document and than created another document: "spreadsheet_test_02.fcstd" and within this document I created a link to the 01 spreadsheet of the first document. Finally I tried to access the alias "test" of the linked spreadsheet by using "=Link_01.test" however this only gives me "#ERR"
However I found that it will work if I use it like this "=spreadsheet_test_01#Spreadsheet.test", which is fine for me at the moment.
spreadsheet_test.tar.gz
(4.36 KiB) Downloaded 17 times
realthunder
Postby realthunder » Wed Jul 18, 2018 10:40 pm
This is indeed a bug. I'll fix it soon. Thanks for reporting.
realthunder
Postby realthunder » Wed Jul 18, 2018 10:43 pm
Right, this is a feature yet to be implemented. You just reminded me. I am already planning a new release (0.8) now. I'll most likely add this feature in 0.9.
freedman
Postby freedman » Thu Jul 19, 2018 10:03 pm
realthunder wrote:
Wed May 16, 2018 7:46 am
freedman wrote:
Wed May 16, 2018 7:41 am
It's late here, tomorrow.
Thanks
Sure, no hurry. Just a guess. Try toggle "Preference->Display->3DView->Use OpenGL Vertex Buffer Object". It sounds like some display problem, and it usually goes away when you disable this option.
I wrote this months ago and thought I would wait awhile and try again later. I just downloaded the latest Assembly3 and the same display problem is still there. Don't get me wrong, i'm sure you have plenty to do. Is this an issue with many users? I want to try Assembly3, it seems that others can use it, not sure if it's OS or what. Open GL makes no difference.
The pic is a puck and a cylinder.
Thanks
OS: Windows 7
Version: 0.18.14058 (Git)
Branch: (HEAD detached at FETCH_HEAD)
Hash: 7e5b332370b07f7fa41190033f9295eb3a6faa10
Python version: 2.7.14
OCC version: 7.2.0
realthunder
Postby realthunder » Thu Jul 19, 2018 10:31 pm
Thanks
Can you please attach your file here? Also it will be better to capture a screenshot to show your problem. Also, please try 'View->Standard views->Fit all' and see if it helps.
freedman
Postby freedman » Fri Jul 20, 2018 12:12 am
Here you go. The zoom-full looks the same.
Everything looked correct when the solids came in and when I created the assembly, but when I start to rotate them in the drawing window the screen weirds out.
Thanks
assem_2nd.FCStd
(19.31 KiB) Downloaded 13 times
realthunder
Postby realthunder » Fri Jul 20, 2018 1:15 am
I couldn't reproduce your problem. Based on your screenshot, it looks like something wrong with the view volume. Either the near or far view clip plane is somehow messed up. I can't think of any possible cause. Do you have any external workbench installed? I've attached a file with three copies of bodies you created. One set in assembly, one set in part group, and the other set is not in any container. Can you please try toggle the visibility of various sets, and see any changes?
Also, please attach a picture of your Display preference setting.
assem_2nd.FCStd
(39.04 KiB) Downloaded 13 times
freedman
Postby freedman » Fri Jul 20, 2018 1:56 am
No other WB installed.
Preferences attached.
I have it narrowed down a bit more. After I open the file, as I hover over the Parts or Assembly Icon in the tree the screen goes weird. It looks like there is a highlighting occuring. Everything after that is screen messed. That's where it starts and it stays that way until close.
As far as your test file: As soon as I mouse (no click) over any Body/Part/Assy in the tree I see a highlight occur on the solid in the display area. I can see the screen has some ghosting and rotating confirms, the screen is weirded out and the part also goes kind of transparent. They all act about the same because of the highlight.
If I don't go to the tree the screen seems fine.
Thanks
realthunder
Postby realthunder » Fri Jul 20, 2018 2:12 am
You can disable mouse over highlight by right click anywhere in the tree view, unselect 'Tree options -> Pre-selection'. Maybe there is something wrong with transparent rendering on your machine. Can you please set transparency on some objects, and see if there is anything wrong.
