Assembly3 preview
easyw-fc
Re: Assembly3 preview
Post by easyw-fc »
I'm looking for something that is working on main branch and not on A3, so it can be fixed before the merging...
OakLD
Post by OakLD »
Jee-Bee wrote: Wed Aug 15, 2018 10:00 am but i guess multiple bodies still not working ...
Well, it depends on definition of "multiple bodies". I did FEM analysis on welded assemblies in FC 17. I used some solid boolean commands from Part WB to get one object to mesh. If used correctly, it provides valid results.
Regards,
Oak
realthunder
Post by realthunder »
New release is here. Some minor bug fixes. Add a new tutorial of using expression with constraint. I have removed 'Angle' unit, so you can have multi-revolution for easy expressing.
Try Assembly3 with my custom build of FreeCAD at here.
fosselius
Post by fosselius »
Awesome, but offset from bottom is based on angle, will not freecad run modulus 365 on the input angle making the offset be reset to 0 after 365 (when angle 366 is entered)?
Also as noted before, the angle in plane concient seams to lack a "fixed reference" and the same angle values can solve to different solutions. But this is most prune to happen on big deltas.
Btw, any plans on adding "joint/hinge" type of constraint? Like: move freely between 10 degree and 25 degree.
realthunder
fosselius wrote: Thu Aug 16, 2018 4:37 am Awesome, but offset from bottom is based on angle, will not freecad run modulus 365 on the input angle making the offset be reset to 0 after 365 (when angle 366 is entered)?
I have made Angle a PropertyFloat, so no problem here.
Yeah, keep the delta small or else it may jump/skip. SW has this reference entity for angle constraints. But it's not clear to me how it can help here.
That is another 'not clear' part. SolveSpace does not support conditional parameters. I think these motion type of thing is best handled in a dedicated module.
fosselius
Post by fosselius »
It feels like the easiest approach is to make an "abstaction layer" above the solver. having some code checking for "out of scope" angles/distances and then having the code manually updating the angle/distance to min/max and then cause the solver to calculate a new solution.
Solid works "limit mates":
http://help.solidworks.com/2016/english ... swassy.htm
and "Mate controller"
http://help.solidworks.com/2016/english ... roller.htm
And some feel good reading:
https://forum.solidworks.com/thread/203154
OakLD
Post by OakLD »
I've been testing (and still am) the 0.8.1 since the release date and it seems to me like a giant leap forward! Great job! And there's 0.8.2 already... :-)
I found some minor, low priority issues:
1) Array cannot be constrained (or I did not find a correct way to do it)
  File "C:\Users\abcd\Downloads\FreeCAD-asm3-20180811-aee619a0-a2a5d69-Win64\Ext\freecad\asm3\FCADLogger.py", line 83, in _catch
    return func(*args,**kargs)
  File "C:\Users\abcd\Downloads\FreeCAD-asm3-20180811-aee619a0-a2a5d69-Win64\Ext\freecad\asm3\mover.py", line 243, in getMovingElementInfo
    raise RuntimeError('no sub-object in selection')
RuntimeError: no sub-object in selection
2) The command for multiplication of constraints using circles gives sometimes wierd results. First time I got a correct pattern of 25 bases according to the circle pattern, but it was shifted away by a lenght of one side of the pattern. I started again with another corner and this time the original base stayed in the corner and 24 other were all in one point in another corner. The third time I tried the command I got a perfect result. It's a great tool!
Regards,
Oak
realthunder
OakLD wrote: Thu Aug 16, 2018 7:26 am 1) Array cannot be constrained (or I did not find a correct way to do it)
Do you mean you want to constraint the array as a single object? If so, you can do that by wrapping the array in a sub-assembly. For draft array, you need to set its `ExpandArray` property to true to make its element freely movable, so that they can be constrained individually.
Next time this happens, please save the file and send to me. I do encounter circular edge related problems due to some obscure OCCT bug, which can usually be walked around by making a copy of the shape, which I did, but not sure if this is a general solution or not.
OakLD
Post by OakLD »
realthunder wrote: Thu Aug 16, 2018 8:54 am ...you can do that by wrapping the array in a sub-assembly. For draft array, you need to set its `ExpandArray` property to true to make its element freely movable, so that they can be constrained individually.
I'll try that. I used Draft WB Array command, since other array methods (Part Design WB, Linear Pattern Feature) didn't work as expected.
realthunder wrote: Thu Aug 16, 2018 8:54 amNext time this happens, please save the file and send to me. I do encounter circular edge related problems due to some obscure OCCT bug, which can usually be walked around by making a copy of the shape, which I did, but not sure if this is a general solution or not.
It's the same file, which you have already tested (the pattern of concrete bases).
I have another interesting issue, I tried to create 66 links, but the element count set itself to 131 and since then it cannot be set to another value. You can enter a different value, but as soon as you focus elsewhere or hit enter, the element count returns to 131. Of course, I tried to restart FC. I've just installed 0.8.2 and the problem persists. I can choose any number as long as it is 131 :-) :-). The assembly file is "Pole_Ucka.FCstd".
Could you reproduce the issue? Perhaps, I accidentally set something incorrectly to inflict such a behaviour?
Ucko.zip
(64.7 KiB) Downloaded 56 times
Regards,
Oak
jpg87
Post by jpg87 »
Info: I put some elements concerning my vision of assemblies on html pages at the following address :
http://help-freecad-jpg87.fr/02_ass_ind.php
Welcome comments on the post :
https://forum.freecadweb.org/viewtopic.php?f=36&t=30227
My website : http://help-freecad-jpg87.fr updated 2023/11/06
