In this case, you should move the asm3 directory into /home/walter/Software/FreeCad/FreeCAD/build/Ext/freecad/
Assembly3 preview
Re: Assembly3 preview
moved (actually copied with cp -a)
$ ls /home/walter/Software/FreeCad/FreeCAD/build/Ext/freecad
asm3 __init__.py
$ ls /home/walter/Software/FreeCad/FreeCAD/build/Ext/freecad/asm3
assembly.py Gui LICENSE py_slvs_mac sys_slvs.py
constraint.py gui.py mover.py Readme.md sys_sympy.py
deps init_gui.py proxy.py slvs system.py
FCADLogger.py __init__.py py_slvs solver.py utils.py
But it does not get installed. Where is supposed to go after make install ?
asm3 __init__.py
How do you start FreeCAD? You can direct launch FC by running build/bin/FreeCAD, and in this case you'll see the asm3 workbench. I guess you install FC by "make install"? In this case, you need to find your user python site-package by running
python -m site --user-site
Ok thanks realthunder,
now I have created the missing folder freecad in ~/.local/lib/python2.7/site-packages:
$ ls ~/.local/lib/python2.7/site-packages/freecad
asm3 __init__.py
And finally I have the workbench Assembly3.
Probably there is the need to add something into the cmake files so that these action are handled inside of the make install.
asm3 __init__.py
I can confirm that you do not get a .local/lib folder after make install. I only have a .local/share. I am running Ubuntu 18.04
Here is the step-by-step how i got asm3 running:
maiden@horse:~$ python -m site --user-site
/home/maiden/.local/lib/python2.7/site-packages
maiden@horse:~$ ls /home/maiden/.local/lib/python2.7/
ls: cannot access '/home/maiden/.local/lib/python2.7/': No such file or directory
git clone https://github.com/realthunder/FreeCAD_assembly3.git asm3
cd asm3/
git submodule update --init slvs
cd slvs/
git checkout python
git submodule update --init extlib/libdxfrw
mkdir build
cd build/
cmake -DBUILD_PYTHON=1 ..
make _slvs
cd ..
mkdir py_slvs
echo "" > py_slvs/__init__.py
cp slvs/build/src/swig/python/slvs.py py_slvs/
cp slvs/build/src/swig/python/_slvs.so py_slvs/
cd ..
ln -s [ABSOLUTE PATH]/asm3 [FreeCAD LinkStage3]/build/Ext/freecad/
cd [FreeCAD LinkStage3]/build/bin/
./FreeCAD
But why you do not simply add a "CMakeLists.txt" inside of Ext/freecad/asm3 directory which install all stuff into INSTALL_DIR/Ext/freecad
(or in INSTALL_DIR/Mod).
and, of course, the following line somewhere in Ext/freecad:
add_subdirectory(asm3)
This is the way all other module are installed. Why Assembly3 has to be installed apart in side of /.local/lib/python2.7/site-packages/freecad ?
Assembly3 is meant to be an external module, because of license issue. And FC new style python module is meant to be installable through pip, which I haven't add support yet, because not many people want to build the entire FC on their own, and there is pre-built image available. Those intermediate site-packages directory are supposed to be taken care of by pip.wsteffe wrote: ↑Tue Aug 21, 2018 10:16 am But why you do not simply add a "CMakeLists.txt" inside of Ext/freecad/asm3 directory which install all stuff into INSTALL_DIR/Ext/freecad
Oh, I see realtunder, it seems a good idea to let it installable trough pip.
perhaps you could have put only the solvespace part in the src/Ext folder keeping GUI assembly.py constraint.py ... inside of src/Mod.
But may be you have done in this way because you consider Assembly3 as a simply wrapper of solvespace constraint solver.
Hello I am getting the folowing error message (repeated several times) inside of the Report view:
Show.TempoVis.isIn3DView error: No module named pivy
But all seems working well. Am I missing something ?
Another report for the module:
AxialAlightment constraint fail to solve in some cases when two cylindrical faces are used to define the constraint.
Video and the test assembly:
OS: Ubuntu 18.04.1 LTS
Version: 0.17.5235 (Git shallow) AppImage
Build type: None
Branch: LinkStage3
Hash: ccaa87e12aaadbd3106607fc503542a863b742da
Python version: 2.7.6
Qt version: 4.8.6
Locale: Polish/Poland (pl_PL)
Build type: None
Branch: LinkStage3
Qt version: 4.8.6
