So, how can we pack the whole drawing into one visible part?A part can only be imported from a FreeCAD document with exactly one visible part. Aborting operation
[SOLVED] How to make a STEP file contain exactly one visible part?
When a part has more than one visible parts Assembly 2 refuses to import the part with the following error:
Assembly 3 notes: https://github.com/ceremcem/freecad-notes
Re: How to make a STEP file contain exactly one visible part?
Why not copy the file and make the objects alternately visible?
The answer was laying in a forum post:
Do you mean separating objects into different documents? If so, the reason why I can't do it is that the drawing consists of about a hundred of sub-parts which will consume huge amount of time.
That's what I had in mind, but your argument is very convincing. I had thought you wanted to place the subobjects in changing positions.
