Anyway to highlight the assembly constraints?
kbwbe
Re: Anyway to highlight the assembly constraints?
Post by kbwbe »
Hi Koemi,
i also registered the problems with obscure constraints in assembly2. But i am not the developer of that workbench and not able to change that behavior.
I made a small macro which toggles the transparency of a whole assembly.
If the first part, the macro has found, is not transparent, the whole assembly changes to transparent mode. (and vice versa back on next run...)
Here is the makro-code:
import FreeCADGui,FreeCAD
doc = FreeCAD.ActiveDocument
NONTRANSPARENT = 0
TRANSPARENT = 80
desiredTransparency = NONTRANSPARENT
# Get transparency of first visible object
for obj in doc.Objects:
    if hasattr(obj,'ViewObject'):
        if hasattr(obj.ViewObject,'Transparency'):
            if (obj.ViewObject.Transparency == NONTRANSPARENT):
                desiredTransparency = TRANSPARENT
        break
# set transparency of objects...
            obj.ViewObject.Transparency = desiredTransparency
For use copy the attached makro-file to your makro-folder and test it.
klaus
toogleTransparency.FCMacro
(617 Bytes) Downloaded 58 times
KBWBE
Koemi
Post by Koemi »
Thanks kbwbe, works perfect! :D
tomerp
Post by tomerp »
Hi Klaus
thanks for your article it is great. I wonder - how can we make your code run as soon as a constraint is selected without having to press the "Show constraint" Button?
See my thread on this matter here:
https://forum.freecadweb.org/viewtopic.php?f=10&t=30175
Please let me know
Thanks
Tomer
kbwbe wrote: Wed Apr 18, 2018 4:28 pm Hello ceremcem,
i think it is simple to modify assembly2 by yourself.
I am already working with an modified version, which i did last time.
At short: You have to extend freecad a little bit. I created a new command with i copied to importpart.py, which is located in your mod-folder and there within the assembly2 folder.
here is the code for the command-extension:
class ViewConnectionsCommand:
    def Activated(self):
        selection = [s for s in FreeCADGui.Selection.getSelection() if s.Document == FreeCAD.ActiveDocument ]
        if len(selection) == 0: return
        FreeCADGui.Selection.clearSelection()
        connectionToView = selection[0]
        if not 'ConstraintInfo' in connectionToView.Content and not 'ConstraintNfo' in connectionToView.Content:
            return # Selected Object is not a connection/constraint
        # Save Transparency of Objects and make all transparent
        transparencyList = []
                    transparencyList.append(obj.ViewObject.Transparency)
                    obj.ViewObject.Transparency = 80
        FreeCADGui.Selection.addSelection(
            doc.getObject(connectionToView.Object1),
            connectionToView.SubElement1
            doc.getObject(connectionToView.Object2),
            connectionToView.SubElement2
        #FreeCADGui.SendMsgToActiveView("ViewSelection") # not good enough
        flags = QtGui.QMessageBox.StandardButton.Yes
        msg = "Close Connection ViewMode ?"
        response = QtGui.QMessageBox.information(QtGui.qApp.activeWindow(), "Highlighting ready", msg, flags )
        # restore transparency of objects...
        i=0
                    obj.ViewObject.Transparency = transparencyList[i]
                    i+=1
        FreeCADGui.Selection.addSelection(selection[0])
    def GetResources(self):
        return {
            'Pixmap'  : a3lib.pathOfModule()+'/icons/a3_viewConnection.svg',
            'MenuText': 'show connected elements',
            'ToolTip': 'show connected elements'
FreeCADGui.addCommand('a3_ViewConnectionsCommand', ViewConnectionsCommand())
The command turns all parts of the assembly to transparency and highlights the components of an selected constraint.
I dont have much time at the moment and have to leave the house within a few minutes, shortly i will tell you more...
p.s.: PLEASE PROVIDE YOUR SYSTEMINFORMATION...
regards,
Klaus
kbwbe
Post by kbwbe »
tomerp wrote: Tue Aug 14, 2018 6:09 am Hi Klaus
Please let me know
Hi Tomer,
do not have much time at moment as development of my new assembly-WB A2plus is eating up all my free time.
You can have a look at the sourcecode of A2plus, especially a2p_importPart.py and a2plib. I think everything you need you will find there.
Behaviour of A2plus:
- select one Constraint
- hit button "viewConnections"
- once you entered "viewConnections" mode:
- assembly gets transparent
- the constraint is shown
- you can select other constraints, A2plus will show new selected constraints instantly
- and so on...
- if deselecting by click on 3D View background, viewConnections mode will be terminated.
KBWBE
ceremcem
Post by ceremcem »
I figured out that at the time of posting the topic, I didn't set "Notify me on reply" option explicitly, so I was not aware of the replies for a long time. When I saw, I was already dove into Assembly3, so I didn't give any feedback. Now I see the progress and I want to thank you for your help. I'm also glad to see it was useful for other users or I would feel remorse.
tomerp
Post by tomerp »
Hi Klaus
I wanted to thank you but i fear a2plus is pretty buggy for me. I am unable to continue my work using it since it keeps deleting parts from my assembly when i delete constraints, and other wierd behaviours. I will try to reproduce and help you fix. Unless you are aware of issues.
Meanwhile i will also try to continue working with assembly 2
thanks
Tomer
kbwbe wrote: Tue Aug 14, 2018 4:23 pm
Please let me know
Hi Tomer,
- and so on...
kbwbe
Post by kbwbe »
tomerp wrote: Sun Oct 21, 2018 7:08 am Hi Klaus
Hi Tomer,
i would be very interested in a detailed error description, as i do not register such bugs on here.
Please provide also your systeminformation.
KBWBE
herbk
Post by herbk »
Hi Tomer,
i'm playing around a lot atm with A2plus and can't confirm that behavior.
Atm i'm at
OS: "openSUSE Leap 42.3"
Version: 0.18.14995 (Git) AppImage
Hash: 7b866816785ac1ca9787b63d4bff12873bb3a593
Python version: 2.7.6
Qt version: 4.8.6
but also at the commits before i don't see that.
Gruß Herbert
