Hi Turro,Turro75 wrote: ping
first feed back regarding your PR with two solvers.
I had to switch back to spinstep-divisor/weights used within master. When i did this, the new second "merge+master" solves most cases, but not all.
I think it has nothing to do with the parameters mentioned above. There must be another difficulty. Perhaps it has something to do with merging of rigids. Perhaps the merging happens at poor accuracy level. If unfixing is not able to unmerge the rigids, there will be problems.
Because lack of time, i did not have an intensive look at the new code. I will do this soon.
If the problematic cases have to do with merging, there two possibilities:
- merging of rigids at an enhanced accuracy level
- unmerging if needed and possible
My opinion tends to the enhanced accuracy level. Next days, we will know more.
In generally, your new solver is much faster and it is worth to invest some work.
I attach a simple file. Master solver works, master+merging not. (old parameters 12.0/0.5/8.0)
If we get the new solver working correctly on this small file, i think we will have found main part of the difficulties)
