Hi Guy's,
here an demonstration of "toponaming light" of A2p:
I designed a baseplate and another part, which is mounted two times on it. I fixed the parts by circularEdge constraints.
After that, i heavily modified the baseplate and the other part. When i did updateImportedParts, the assembly kept stable and everything looks like expected.
See here the original assembly:
and here the updated one after editing both involved parts:
Without use of toponaming, the assembly would sure break.
Files are attached as ZIP, for those who are interested...
- After-Edit.zip
- (121.43 KiB) Downloaded 40 times
- Before-Edit.zip
- (51.07 KiB) Downloaded 45 times
KBWBE
- manuelkrause
Hi Klaus,kbwbe wrote: ↑Sat Oct 20, 2018 4:28 pm Hi Guy's,
this is a really good proof of working of your Toponaming/ Topomapping!
Looks great!
- manuelkrause
BTW, as you use transparency in these cases for the smaller parts and you use FC 0.18:
When you import the final assembly (as single object .fcstd) into a new assembly file: What does happen to the colors/ transparencies?
BR
Very unspectacular, colors where imported, transparency is set manually after import!manuelkrause wrote: ↑Sat Oct 20, 2018 5:32 pm BTW, as you use transparency in these cases for the smaller parts and you use FC 0.18:
KBWBE
Another test with A2p and activated topological naming.
Please find here two screenshots.
- First one with some boxes including a hole and a bolt.
- Second one with box modified by thickness and changed dimensions.
Used constraints: circularEdge, axisCoincident, planesCoincident.
The assembly keeps stable after editing and reimporting the box.
Before edit: .
After edit: .
This is the console output for updating the subelements during updateImportParts command:
Testfiles are attached as ZIP
Before edit: .
After edit: .
oldConstraintString (KEY) : E;Box;12;12;
Updating by SubElement-Map: Edge9 => Edge7
oldConstraintString (KEY) : E;Box;6;12;
Updating by SubElement-Map: Edge10 => Edge13
oldConstraintString (KEY) : F;Box;1;6;
Updating by SubElement-Map: Face1 => Face1
oldConstraintString (KEY) : F;Box;3;6;
Updating by SubElement-Map: Face2 => Face6
oldConstraintString (KEY) : F;Box;6;6;
Updating by SubElement-Map: Face3 => Face5
oldConstraintString (KEY) : E;Box;9;12;
Updating by SubElement-Map: Edge5 => Edge10
oldConstraintString (KEY) : E;Box;4;12;
Updating by SubElement-Map: Edge4 => Edge4
oldConstraintString (KEY) : E;Pocket;1;3;
Updating by SubElement-Map: Edge8 => Edge11
oldConstraintString (KEY) : F;Box;2;6;
Updating by SubElement-Map: Face6 => Face7
oldConstraintString (KEY) : F;Box;5;6;
Updating by SubElement-Map: Face5 => Face3
- After-Edit.zip
- (30.52 KiB) Downloaded 38 times
- Before-Edit.zip
- (23.52 KiB) Downloaded 39 times
KBWBE
- manuelkrause
Hi Klaus,
quite a nice evolution of A2plus, I'd say.
I've just re-done my Pleuel file for more simplified overall geometry definitions, thus leaving many earlier constraining points to vanish (sketch changes).
The new devel branch complained about 4 constraints to be fixed, which corresponds to my changes minus 1 change. I've written them down to paper and tried to consecutively fix them. But when I update inbetween I can get several new complaints of failing constraints that were good before (!) and that can be good again after finding the one right culprit constraint.
Still some things depend on too much luck or strategy. I'd attach the new "Pleuel", it should fit in your previous loaded Pleuel-assembly files by measurements.
But the base functionality has greatly improved, no idea, what earlier versions or even Assembly2 would have done...
BR,
Manuel
- Pleuel-4.fcstd
- renewed simplified shape for testing
- (39.03 KiB) Downloaded 40 times
Hi Manuel,manuelkrause wrote: ↑Mon Oct 22, 2018 6:56 pm The new devel branch complained about 4 constraints to be fixed, which corresponds to my changes minus 1 change. I've written them down to paper and tried to consecutively fix them.
are you trying to rework an existing assembly in order to use toponaming ?
KBWBE
I have seen you are working on TopoNaming features now and therefore assumed solver development likely has matured by now. I had small size project with few parts in need to be assembled. And decided it's time to give A2plus a try again. The experience was straightforward and assembling procedure was achieved in rather fast and robust way. To be honest i am impressed. I didn't have to change a single constraint in the whole procedure. It just worked as i expected it should.
P.S. I might have detected a small bug in the process. When holding down the Shift key and trying to duplicate a part. Should that come down to easily being able to make multiple copies of the part? As on my side it looks like only one copy can be made each time the duplicate part command is used.
Thank you very much for your feedback.
It's not inside code ATM. During rework of Assembly 2 towards A2plus i messed out everything i did not need at this point, to avoid bugs. I will reimplement it in some time.triplus wrote: ↑Mon Oct 22, 2018 11:19 pm P.S. I might have detected a small bug in the process. When holding down the Shift key and trying to duplicate a part. Should that come down to easily being able to make multiple copies of the part? As on my side it looks like only one copy can be made each time the duplicate part command is used.
KBWBE
- manuelkrause
Hi Klaus,kbwbe wrote: ↑Mon Oct 22, 2018 7:47 pmHi Manuel,manuelkrause wrote: ↑Mon Oct 22, 2018 6:56 pm The new devel branch complained about 4 constraints to be fixed, which corresponds to my changes minus 1 change. I've written them down to paper and tried to consecutively fix them.
yes, it was an existing assembly, but IIRC already assembled with a toponaming-A2plus.
I don't know if this (my) workflow is allowed: I've manually changed the Pleuel-filename in the assembly's properties to the changed part-name and then reloaded imported parts.
In fact there had been so many faces, edges and points removed in the new part, that I can be glad that the A2plus solver + toponaming can figure out at least one existing constraint at all -- and the re-work was quickly done. Only problematic part of it was to identify the "killer"-constraint leading to the error messages.
So, please don't take my report as too important.
