kbwbe
Postby kbwbe » Tue Mar 19, 2019 8:34 pm
detlet wrote:
Tue Mar 19, 2019 6:23 pm
I don't know if I got you right here, so I attach the "broken" file.
Please see first screenshot of file "incorrect-cut.fcstd"
Part WB cut is applied to Pad and Revolution, which are inside of bodies. This is not allowed and you get the message "Part::Cut: Links go out of allowed scope". A2plus will not import this cut correctly.
Please see second screenshot of file "correct-cut.fdstd".
Part WB cut is applied to Body and Body001. There is no error written to console and this is ok. A2plus imports it fine...
I attach both files. I hope this helps to explain the difference.
incorrect-cut.FCStd
(23.23 KiB) Downloaded 18 times
correct-cut.FCStd
(23.33 KiB) Downloaded 19 times
KBWBE
latest release: v0.4.47, installable via FreeCAD's addon manager
detlet
Postby detlet » Wed Mar 20, 2019 4:18 pm
now I got it. Thank you! There remains a question, that is most probably wrong here :D : If the kind of cut I made is wrong and the result not allowed, why is it not prevented by FreeCAD, even if FreeCAD detects the error? Or is there a reasonable use case for the wrong way? For me it would be very helpful if such thing where prevented, because I _never_ open the report view.
manuelkrause
Postby manuelkrause » Wed Mar 20, 2019 4:51 pm
IMHO, the Part WB should throw a visible Error Message window for this case.
I'm thankful for @kbwbe's guidance on how to make it right. And I hope to remember it in future.
Manuel
detlet
Postby detlet » Wed Mar 20, 2019 6:09 pm
I hope that I don't bug you. But I have the next issue.
It seems to me that sub-assemblies do not like balls / spheres. If I have an assembly which contains a ball, where it doesn't matter if it is a Part ball or a handish made PartDesign one, and I include this assembly into an other assembly, the sub-assembly will lose it's colors. If in the sub-assembly the ball is made invisible, after saving and recalculating the master-assembly the visible parts of the sub-assembly will get theirs colors back.
I've attached a very simple example with a bush and a ball
the ball this time made with PartDesign
ball-a2plus.FCStd
(10.99 KiB) Downloaded 25 times
the master assembly
ball-a2plus-ass.FCStd
(8.75 KiB) Downloaded 24 times
and the sub-assembly
ball-a2plus-sub.FCStd
(9.84 KiB) Downloaded 24 times
Cheers, detlef
kbwbe
Postby kbwbe » Wed Mar 20, 2019 9:48 pm
Joke: Yes you do ! ;) Joke left aside: You have found a bug ! :?
I did first test. I did not only miss the correct colors, i also missed the complete ball at second level import. It has to to with number of faces == 1 for a ball. When i created a drill hole within the ball, it has more than one face and it appears with correct colors.
I will look for that tomorrow.
KBWBE
kbwbe
Postby kbwbe » Thu Mar 21, 2019 10:39 am
This should be fixed with version V0.4.7. Please update your A2plus WB.
KBWBE
detlet
Postby detlet » Thu Mar 21, 2019 5:53 pm
works also with an other assembly from me. Tank you for the fast fix!
kbwbe
Postby kbwbe » Sun Mar 24, 2019 1:42 pm
Hi guys,
a new version of A2plus is out: V0.4.10 .
Some small things are new:
- The part labels from the tree view can be displayed in the 3D view
(useful for a quick documentation of an assembly via screenshot + partslist)
This are the new buttons:
- improved pointOnPlane constraint: As point definition a sphere (it's center) can be used.
- improved pointOnLine constraint: As point definition a sphere can be used and as line definition an axis of a cylinder.
(This allows more constraining to spheres)
Have fun !
KBWBE
Turro75
Postby Turro75 » Mon Mar 25, 2019 7:55 pm
Hi guys,
Hello Klaus!
very good, would it make sense taking the label text from a specific column from parts list spreadsheet?
Regards
Valerio
kbwbe
Postby kbwbe » Mon Mar 25, 2019 9:51 pm
Hi Turro,
i am very pleased to hear you after some time.
Obviously i did not think about this topic deep enough, as it was working according to my common working style. (and unfortunately not for others who are working differently)
Doing my way is:
- filename = part's ID number (i manage my parts by a data base)
- label in tree view = filename (automatically done by A2plus) = part's ID
- label on screen = label in treeview = part's ID
When working this way, someone gets a result like this for example:
So even there does not exist a partlist at time of labeling, i could identify the parts (and their files) by screen labels.
But as told before, this works but is perhaps not the standard way of documentation for other users.
One method i know from other machinery docs is to use the POS-number of the partslist to be drawn to the assembly. This is also not very difficult to implement. But in this case partslist has to be done before.
The labeling code could be made dependent on condition whether a partslist exists or not. In latter case the position number could be used. Is that what you are looking for ?
KBWBE
