kkremitzki
Postby kkremitzki » Wed Apr 10, 2019 3:52 am
The long term fix of course is for me to fix my patch which caused this, but I need to make some changes elsewhere to preserve the behavior I made the patch for in the first place.
kbwbe
Postby kbwbe » Wed Apr 10, 2019 10:10 am
Hi all,
I just detected, that the new version string of FC0.18.1 also broke the solving of constraints.
This is fixed with A2plus version v0.4.14
Please update your A2plus WB.
KBWBE
latest release: v0.4.47f, installable via FreeCAD's addon manager
m.cavallerin
Postby m.cavallerin » Wed Apr 10, 2019 10:15 pm
Could be possible to add this functionality for a Top - Down Modelling?
https://www.youtube.com/watch?v=tvzAcA8KNg0
here's follow the Macro, but I'm sure some skilled man could improve it.
import os
import a2p_importpart as update
import PartDesignGui
assemblyName = App.ActiveDocument.Name
sel = FreeCADGui.Selection.getSelection()
update.a2p_EditPartCommand.Activated(sel)
pathPart = App.ActiveDocument.FileName
nameFile = App.ActiveDocument.Name
fN = App.getDocument(nameFile) #dleggo la struttura del file
skPath = fN.Objects[0].sourceFile
labelSk = fN.Objects[0].Label
FreeCAD.openDocument (skPath)
nameSk = App.ActiveDocument.Name
obj = App.ActiveDocument.RootObjects
for i in obj:
	if i.Label == nameFile:
		 Gui.showObject(i)
	else:
		Gui.hideObject(i)
FreeCAD.ActiveDocument.save()
FreeCAD.setActiveDocument(nameFile)
update.a2p_UpdateImportedPartsCommand.Activated(labelSk)
FreeCAD.setActiveDocument(assemblyName)
update.a2p_UpdateImportedPartsCommand.Activated(sel)
FreeCAD.closeDocument (nameSk)
FreeCAD.closeDocument (nameFile)
f3nix
Postby f3nix » Sat Apr 13, 2019 7:12 pm
Hi!
kbwbe wrote:
I hope this is right place to ask.
I have a problem with constraining one part in my test assembly.
No plane constraints are available for DTW50W_scanner (axial and circular work well). Any idea what might be wrong?
Test file attached.
A2plus version 0.4.15
OS: Debian GNU/Linux buster/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.16474 (Git)
Build type: Debug
Hash: 746997e48411f22a150b95b6fdbb9b02cbe741d5
Python version: 2.7.16
Qt version: 5.11.3
Locale: Polish/Poland (pl_PL)
Cheers,
Mateusz
UPDATE: Assembly 2 does not have any problem constraining this part...
test_v1.FCStd
(114.9 KiB) Downloaded 19 times
kbwbe
Postby kbwbe » Sat Apr 13, 2019 9:16 pm
Cheers,
Mateusz
Hi Mateusz,
i had a look at your file. The problematic part (DTW50W_scanner) does not have plane faces. Everything what seems to be a plane face is a BSplineSurface object in reality. Therefore A2plus does not accept them.
A2plus does not support BSplineSurfaces at moment. (Assembly2 does...)
Have a look at the report view in the following screenshot..
KBWBE
f3nix
Postby f3nix » Sat Apr 13, 2019 10:04 pm
Hi Mateusz,
Thank you for a _very quick_ answer! :) Now I can stop banging my head against the wall.
FYI the model comes from the manufacturer in IGES format.
kbwbe wrote: A2plus does not support BSplineSurfaces at moment. (Assembly2 does...)
Ok. I'll try to work around this.
Thank you for your great work! :)
Cheers,
Mateusz
f3nix
Postby f3nix » Sat Apr 13, 2019 11:39 pm
I have come up with this hack but it does not work as expected yet. Do you have any pointers what else should be changed? It creates broken constraints.
Thank you!
diff --git a/a2p_constraints.py b/a2p_constraints.py
index 01f7d1f..155d5cd 100644
--- a/a2p_constraints.py
+++ b/a2p_constraints.py
@@ -513,8 +513,20 @@ class PlaneConstraint(BasicConstraint):
         c = self.constraintObject
         plane1 = getObjectFaceFromName(self.ob1, c.SubElement1)
         plane2 = getObjectFaceFromName(self.ob2, c.SubElement2)
-        normal1 = plane1.Surface.Axis
-        normal2 = plane2.Surface.Axis
+        if str(plane1.Surface) == '<BSplineSurface object>':
+            plane_norm, plane_pos, error = fit_plane_to_surface1(plane1.Surface)
+            normal1 = FreeCAD.Vector(plane_norm[0], plane_norm[1], plane_norm[2])
+            Msg('Normal 1 - my:{}\n'.format(normal1))
+        else:
+            normal1 = plane1.Surface.Axis
+            Msg('Normal 1:{}\n'.format(normal1))
+        if str(plane2.Surface) == '<BSplineSurface object>':
+            plane_norm2, plane_pos2, error2 = fit_plane_to_surface1(plane2.Surface)
+            normal2 = FreeCAD.Vector(plane_norm2[0], plane_norm2[1], plane_norm2[2])
+            Msg('Normal 2 - my:{}\n'.format(normal2))
+        else:
+            normal2 = plane2.Surface.Axis
+            Msg('Normal 2:{}\n'.format(normal2))
         angle = math.degrees(normal1.getAngle(normal2))
         if angle <= 90.0:
             self.direction = "aligned"
diff --git a/a2plib.py b/a2plib.py
index cc8ef92..657a8fc 100644
--- a/a2plib.py
+++ b/a2plib.py
@@ -33,6 +33,9 @@ import sys
 import copy
 import platform
 from a2p_viewProviderProxies import *
+import numpy
+crossProduct = numpy.cross
+dotProduct = numpy.dot
 PYVERSION =  sys.version_info[0]
@@ -97,6 +100,14 @@ else:
     OPERATING_SYSTEM = "OTHER"
+def fit_plane_to_surface1( surface, n_u=3, n_v=3 ):
+    uv = sum( [ [ (u,v) for u in numpy.linspace(0,1,n_u)] for v in numpy.linspace(0,1,n_v) ], [] )
+    P = [ surface.value(u,v) for u,v in uv ] #positions at u,v points
+    N = [ crossProduct( *surface.tangent(u,v) ) for u,v in uv ]
+    plane_norm = sum(N) / len(N) #plane's normal, averaging done to reduce error
+    plane_pos = P[0]
+    error = sum([ abs( dotProduct(p - plane_pos, plane_norm) ) for p in P ])
+    return plane_norm, plane_pos, error
 def to_bytes(tx):
@@ -604,6 +615,8 @@ def planeSelected( selection ):
             face = getObjectFaceFromName( selection.Object, subElement)
             if str(face.Surface) == '<Plane object>':
                 return True
+            elif str(face.Surface) == '<BSplineSurface object>':
+                return True
     return False
 def vertexSelected( selection ):
Cheers,
Mateusz
kbwbe
Postby kbwbe » Sun Apr 14, 2019 10:53 am
Cheers,
Mateusz
Hi Mateusz,
thank you for your effort. I reworked your code and implemented it to A2plus. Now it accepts (flat) BSplineSurfaces as plane references.
This is the commit, if you want to have a look at the changes...
https://github.com/kbwbe/A2plus/commit/ ... adac4d078d
Please update your A2plus WB to V0.4.16
KBWBE
triplus
Postby triplus » Sun Apr 14, 2019 2:06 pm
Cheers,
Mateusz
Hi Mateusz,
Thanks to both of you.
f3nix
Postby f3nix » Sun Apr 14, 2019 6:48 pm
Thank you! :)
It works like a charm.
Credits should go to @hamish2014 for his fit_plane_to_surface1 function.
Have a nice one.
Cheers,
Mateusz
