Hi Klaus,
Let us more work on debugging:
- Controller_III.jpg (193.11 KiB) Viewed 1487 times
Point_I:
I builded a master cube to make the housing more stable when i make changes. To look anytime through them i gave them a transparency of 80.
After save, close and load the assembly file the transparency number is 80 but the master cube are not transparent. I must overwrite the transparency nummer to look through the master cube.
Point_II:
The master cube has no transparency when i end the 'show connected elements' function.
The transparency number is still 80. I overwrite the transparency number and it is now transparent.
Point_III:
I can not end the 'show connected elements' function in Open Inventor Modus. The end routine recognize not the CTRL-Mouse Left-Click.
Point_IV:
When i gave a Part in a subassembly the Material info, this Info comes not in the masters assembly.
Point_V:
When i combine Parts with Parts out of the Fasteners-WB with 'convert parts in a2 plus form' i cannot generate the spreadsheet of partslist.
Regards
Walter
p.s
Info of my System:
- OS: Windows 7
Version: 0.18.15481 (Git)
Hash: 763b5c362fe4b98dca858f86f5d1353075224651
Python version: 2.7.14
OCC version: 7.2.0
